  • Replies 43
the get new posts thing is acting oddly. it comes up fine but when i try to access page two of the search i get this:
i havent tried any other searches to see if its common to all of them. im running xp and ff3
EDIT: same thing with the "get active topics for: today" function
Heres a quick and dirty rundown;
The site has been moved to a new server and the old server has had its config updated to point to the new servers db. This means we have one db and two 'sites' until everybodies DNS is updated. Because I have fixed the search on the new server, people who are still getting the old server's 'site' will have some problems, but they will be fixed when the users' DNS is updated. (ie, I can search and view new posts with no errors at all).
Hopefully that makes sense, its hard to explain DNS stuff without pictures. Ask any q's, I might have to reply using an ms paint representation. :(:P:(
Christian
The error returned was:
Erreur Sphinx : connection to localhost:3312 failed
Merci de contacter un Administrateur !
Is this the DNS related issue still? Ive cleared the caches on my DNS servers and still cant get access.
Do this for me;
Open command prompt: Start -> Run -> Type 'cmd' -> Hit Enter
Type;
nslookup <enter>
set q=any <enter>
skylinesaustralia.com <enter>
skylinesaustralia.net <enter>
And then post the output here. (You may need to enable cut n paste, right click on the title bar of cmd, go to properties and tick 'quick edit').
> set q=any
Server: UnKnown
Address: 172.16.1.1
DNS request timed out.
timeout was 2 seconds.
*** Request to UnKnown timed-out
Server: UnKnown
Address: 172.16.1.1
skylinesaustralia.net nameserver = ns1.nexcess.net
skylinesaustralia.net nameserver = ns2.nexcess.net
skylinesaustralia.net MX preference = 10, mail exchanger = mail.skylinesaustra
lia.net
primary name server = ns1.nexcess.net
responsible mail addr = admin.skylinesaustralia.net
serial = 1219358344
refresh = 7200 (2 hours)
retry = 2048 (34 mins 8 secs)
expire = 1048576 (12 days 3 hours 16 mins 16 secs)
default TTL = 21600 (6 hours)
skylinesaustralia.net internet address = 208.69.126.31
mail.skylinesaustralia.net internet address = 208.69.126.31
> set type=ns
Server: UnKnown
Address: 172.16.1.1
Non-authoritative answer:
skylinesaustralia.com nameserver = ns1.nexcess.net
skylinesaustralia.com nameserver = ns2.nexcess.net
ns1.nexcess.net internet address = 69.39.81.205
ns2.nexcess.net internet address = 208.69.120.2
Server: UnKnown
Address: 172.16.1.1
And this too. Looks like your authorative DNS servers arent accepting connections so everyone is running from cached records in DNS even though the TTL has probably expired.
> set type=a
> server ns1.nexcess.net
Default Server: ns1.nexcess.net
Address: 69.39.81.205
> www.skylinesaustralia.com
*** Request to ns1.nexcess.net timed-out
> www.skylinesaustralia.net
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
