Hey guys just need some recommendations on who would be good to tow my r33, it only needs to be towed from my old house to a friends house (15 mins away) so just a real quick job....
i tried doing a search but it wasn't working id assume due to the server upgrades recently....
Any help will be greatly appreciated :huh:
https://www.sau.com.au/forums/topic/232573-car-towing-help/
Must admit I've never used them, but these guys have the absolute best name in towing, click the link you wont be disappointed.
http://www.yellowpages.com.au/onlineSoluti...b590e&st=bn
In all seriousness I've used dial-a-tow (make sure you let them know if it's lowered so you get the truck) and Full-on and not had any problems with either.
https://www.sau.com.au/forums/topic/232573-car-towing-help/#findComment-4080968
would offer, but trailer needs a couple of electrical gremlins fixed (from my own 10pm wiring job the night before i had to go to melbourne) and its outta rego
other than that, id have been happy to help
have towed my car 1500km round trip to shepparton and back via winton raceway, have also towed ORGZMC's R31 to mallala and return, and 32_4door's (brenton) JZX81 Mark II to Wayville and return. His car got on with no issues whatsoever, and towed like a dream
Edited by Matty 31
https://www.sau.com.au/forums/topic/232573-car-towing-help/#findComment-4082409
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
