RBPOWA, Have a hunt around the forum threads, there a couple of translations of the
glovebox fuses printed out in the same orientation as the fuse box layout.
im in also .. bloody fuse box is killing me ! now just gotta wait for this to take off :S
i've got my owners manual on its way ... it came last week but it was full of useless info on the s14 .. so they sent me out another one .. should be here within the week :) .. very helpfull thats gonna be ...your SE .. you coming cruise? ... check VIC events
Dunno If i will come, on a rotating roster which does not help my cause.
I'll check out date/time and see, havent been to one as yet.
Found the thread on the fuse box, very handy.
http://www.skylinesaustralia.com/forums/St...;hl=stagea+fuse
Do you know were I can get the Jap version of this.....need the wiring diagram? The M35 with the VQ25det motor
I have attached a Apexi wiring PDF for Nissan, Toyota, Honda, Mitsubishi, Mazda, Subaru, Suzuki and Daihatsu.
Hope it helps.
NM35 Stagea is diagram N8-C on page 29.
If the attachment is not working, PM me with your email address & I will forward it on.
Let me know how you go with the Interceptor, dyno sheet pics would be great (and a list of mods).
Can't wait to see what these cars are capable of...
wiring_diagram.pdf
Edited by iamhe77
  • 2 months later...
Since we have a few more Stagea owners, I thought I might give this thread a little push to remind others to register their interest for the translated workshop manuals for C34 & M35 Stageas.
http://www.jpnz.co.nz/afawcs0131170/CATID=...1/products.html
Feel free to register your Hotmail, Gmail etc... accounts also :)
  • 1 month later...
Registered interest for WC34.. nearly at 50.. 6 months and not even 50.. someone convince them to publish at 50!
Could be worse.
M35's are at 18.
Both started at the same time. How many different email address' do you have?
  • 3 weeks later...
Hey all.
Quick update.
The director of JPNZ international has just informed me that 75 expressions of interest are required to translate the Workshop manual for either C34 or M35.
The catch? $200 per manual.
Not too bad considering that for the most part we rarely even blink and spending $200 on our cars.
S1 & S2 are nearly there.
Let's get some M35 numbers going eh?
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
