If you want to down load the R34 +R34 service manual sup I this links are for you
Please PM
They have R33 manuals ,just put what you want in the search box
  • 1 month later...
Ok, hate to spruik for business (actually it's not my business but I could make it so :blink:), but if there's enough interest (the count for the M35 Stagea is 23) I could geta quote to get it done as I have connnections.
The thing is where do I get the Japanese version? Anyone here have one?
Spruik all you want mate.
Would love to get my hands on an English manual for these cars, not names "G35 service manual" (although it is quite useful).
Don't have the Japanese one, but I have seen them from time to time on Import Monster.
i have a japanese manual for my S15, it might have been in japanese, but its was well worth the money i paid for it. who cares what language its in ill take a jap M35 manual if there is one available. everything is in metric anyway so it wont matter!
I bought a set of manuals back in '05
Parts (including prices)
Workshop Manual
Engine Manual
Owners Manual
Having the workshop manual translated would be good, but so far the only things I've really looked at are specifications, which are usually easy enough to interpret.
  • 3 weeks later...
Workshop Manual
Engine Manual
Owners Manual
Scanner please!!!
Vote people Vote
would be great if JPNZ actually translated the full Nissan JP workshop manuals (all 6 volumes, 4 addendums and 2 service manuals). From experience with the skyline manuals the version they end up publishing is well watered down.
Hi
We have just found this thread in the uk and have put a similar sticky in our Stage owners club forum .
Hopefully we will have enough names soon to be able to move this forward
I will keep you posted.
  • 4 months later...
  • 9 months later...
Hey guys
If you are interested in translated workshop manuals for either model Stagea, please register your interest here;
http://www.jpnz.co.nz/afawcs0131170/CATID=...1/products.html
They do require around 100 total requests and are looking at around $150NZD per manual if those numbers are achieved.
Cheers.
Required requests and costs have been updated.
So we have 80 signed up so far, only 20 to go!
Have all the new owners signed up?
C'mon guys, will make servicing and repairs a lot easier. :)
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
