Make: Nissan
Model: gtir 1992
Milage: 66500kms
Transmission: 5speed
Colour: red
Complied? yep
RWC supplied? no
Currently registered? 10mths rego
Price: 11k ono or swap
Contact: 0425284264
Comments / Modifications: I have just fitted 17" matt black bsa racing wheels with new tyres. Car was imported to Australia in Nov/2004
SR20det intercooler t28 turbo, twin cam, 16value, All wheel drive. all power options, Car is immaculate as new for a 92model car with low kms, Paint is in pretty much immaculate condition as is the interior, very reliable, This awd car is a very quick thats good on fuel. car is running on 11 psi its never been boosted over that,
this is a gtir Sr20 engine it is the most strongest out of the sr20 family. It comes stock with a 172kws from factory with a few of my mods it should be around the 180-190kws mark at the fly wheel.
Specs:
- manual tap boost controller
:-18/06/09 rego
- 66200kms
- colour coded moulds and bumpers
- Drift boost gauge and volt meter gauge
- Lion alarm with black wiring with 2 point immobilizer and 2 alarm buttons.
- Rear LSD diff
- Espelir 2.5" lowered springs with KYB NEW SR SPECIAL aftermarket shocks.
- 3" stainless cat back exhaust
- After market fuel computer with 3 fuel maps
- adjustable thermo temp switch
- Apexi alloy over flow tank with apexi radiator cap
- HKS bov
- hks turbo timer
- close ratio gear box with short shifter
- Platinum plugs with 8.8mm spit fire leads
- New genuine nissan water hoes kit with new thermostat
- New kenwood mp3/cd, alpine 6.5" spits
- Hd button clutch for daily driving
- Car has just been fully service with Turbolight MOTUL oils, fresh coolant, fresh platinum plugs, new fuel and oil filter
- Top end engine rebuilt the head has been fully service with new value guides, adjust tappets, and full polish head, vrs kit and arp head studs this still is a under 3mths warranty cost $2400 for this service.
-This car is very rare in factory red most of them are black/white, and car is in top A1 condition, clutch is less than 5k old and has a good bite, air con ice cold, never in any accidents and come with a clean title I have receipts for everything if you add up all my receipts its over 3grand...
Call Andy on 0425284264 for inspection or for any questions
Images: pm me for photos I can't seen to uploan atm.
why did this car with 66,000kms that has never been boosted over stock 11psi and yet has a "boost tap", need a top end engine rebuild?
Stock boost on a sr20 is only 7psi...
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
