Nissan do this, it means you have the special million dollar winning car,
Nah, but unscrew the 4 screws in the speedo, pull it out, check the speedo cable is plugged in properly, if it is, then check the sensor at the other end(gearbox end is still working, follow the cable up, sometimes they snap, if it's buggered just get a new speedo cable, if it's not, then you might need to take it to a mechanic, something must be stopping it from spinning)
If the speedo and P/S are still working, then it shouldn't be a problem with the cable.
The Japanese seem less opposed to fiddling odometers (winding them back). It's possible some sort of damage was done that prevents the odometer going past 100k.
I have the same problem as mine started to play up at 75000kms and fixed itself.
It has now hit 80000kms and wont budge, even the trip meter has stopped.
So I pulled it apart today and had a look seemed easy enough but I couldn't find anything wrong so I just pushed the odometer numbers gently past 80000 with a small screwdriver.
Dunno if this has worked yet as my radiator is out and I cant drive it.
Will let you know as soon as I do tho.
On a side note my boost guage seems to be playing up.
When Im idling the guage reads 0 pressure not vacuum, but when I start to boost it it climbs up.
Also noticed that when the car is off it falls down to 7 deg vacuum.
Any ideas????
I have exactly the same problem.......
the ODO meter stop when reaching 89999kms
yes, four 9 and doesn't go past the 90000kms!
and the trip meter also stopped........
I opened it up and can see nothing wrong
went to wrecker to buy a used one.
realise that the one I had......doesn't have the P, R, N, D, 1, 2......at the centre......
so I am guessing it is for a manual car
and now maybe I could understand why the O/D light doesn't turn on
so what's the reason behind the not running odometer?
i heard that when your car is moving, you shouldn't reset the trip meter..........but I need confirmation about that lol
and also I think it stopped before I reset -_-"
This is what we were concerned about at 5 mins to midnight on 31/12/99 eh?
Had an N13 that did the same thing, and after about 2 months, the odo moved on. Might have been after speed hump rather than a chicane.... Silly isn't it!
Rubber Mallet? I'll LOL if that works!
the car's odometer just stopped in shock when it realised it was the second time it had clicked over 100,000klm :( I guess they wound it back a fair way.
no idea how to fix it but it is pretty common with these cars
pull it apart and look for the cogs from memory there is one white one and severl black ones, check to see if they are all lined up and "meshing" nicely in there, also make sure no damage to the shaft and that everything is plugged in! Gl hame.
    • Give the fluid a really good flush, then go do the same track again. Report back too please
    • I think most of the benefit there is really from the battery as well, having 1 kWh or so means you don't need the engine running at idle to run the AC, when the battery is depleted you can run much higher idle to charge the battery at a lower bsfc point and then shut it back down, you can regen on braking to recover some of that power too. I can't imagine the benefit from only running the compressor as much as needed is huge if you're mostly only running the AC on hot sunny days where it really needs to work hard to keep interior cabin temp under ambient.
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
    • How hard are you tracking it? I have 378 in front and 355 in the back with decent pads and my brakes were spongy after a decent session with lots of braking. It was a short track though but got up to around 190-200 max. be keen to hear. Mind you, I havent flushed my fluid so thats probably part of reason.
    • Awesome thanks for the reply Man! I already plugged up the back just cause I can’t take a chance on it leaking on me again haha. But i will fab a catch can with 2x for the cam covers and a lower one for the sump vent.    Now as this will drain back as well , Is there any concern I should have of the oil being drained back. I don’t run e85 or anything .   2nd question is, from the picture does it seem that my sump fitting is above oil level? Silly question but I rather have someone’s experienced opinion lol
