  • Replies 188
Details? :)
It was ok. She later found it in her handbag along with a tonne of other stuff. She even found a walrus! U guys know what women are like with their handbags. Its like the friggen Tardis...
-D
-D
:D
Golden.
c'mon Tom that's still not saying anything.....do we have to coax it out of you or what?!
Alright alright.
Don't wanna say too much but some bloke (I thnk he was a substitute teacher) had a bit of a go at kahli after some spirited driving this morning. More to the point, he probably thought we were gonna hit him so once we parked, he came up and knocked on the window pretty damn hard and covered our faces with his spit.
I suppose the drift spec look doesn't help either *cough*defect*cough*
Yeah he was a big prick the guy, i didnt even do anything... Last night i took my front bar off for the fun of it and yeah i know its illgeal driving around without it but it looked cool for a day. Anyways. he pretty much grabbed my number for no reason and nearly broke my bloody window! AH! and this morning some ladie was yelling at me in a 50 zone because i had no front bar on, whats it to her issue anyway!!!
chad, would be interesting to see how she does in 2wheel drive, id say nowhere too fast lol...not in a straight line anyways. Im up for hillzy when you are mate.
If your talking about hills, im up for it when i get my suspension done, trust me i do know how to drive.. Tom was enjoying the nice easy drive cough cough this morning while we were late for school.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
