  • Replies 188
Pete, Troy from mildrins does a fair bit of tuning at my mates work Aussie dyno and tune, He also has tuned a fair few PFC's, seems well educated with tuning...usually you can tell just by how they talk and their attitude while they are tuning. Just a thought, You could also keep it in AWD as my mate's dyno is 4WD. Brian Hester is another one who hires out the dyno, years of experience, national rep for HALTECH, but also does PFC's. He has done a fair few GTR's.
food for thought.
Ryan
awesome work on the 32 :P. how many kms it done, manual? (sorry if its been stated earlier. diddnt have time to read through 10 pages)
rb20det's are great little motors. have one in my work car. as damo experienced its a real revvy motor and on 12 pound still a bit of fun.
looking forward to sussing it out.
good luk
Hi Mark, Havent spoken to you in ages..
Its got 148,000kms its a bit but got it cheap so i didnt mind. Yep Manual haha... also has an r33 turbo in it, heavy duty clutch and 3" exhaust all the way to the turbo and gtr kit on it but im changing the kit anyways and getting engine work done to help out the turbo!
food for thought.
Ryan
big +1 for troy, great bloke to deal with. was able to fix a problem on my car other tuners couldnt
RB's hang around Kahli, 148,000 is not so bad. Running stock boost? you could whack a cooler on and up the boost a bit! :wub:
yeh running stock boost atm.. hopefully gettin some of the engine work done in a few weeks hehe... boost boost boost!
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
