This Group Buy will ends on only if I get a minimum order of 50 orders
My trader feedback link: http://www.skylinesaustralia.com/forums/in...=35717&la=0
I have got a mate working in http://www.espadaperformance.com. And thus, I have gotten you guys a very good price on the gauges. Therefore, I post it up here, hoping to share this great deals with you guys.
the product offer is AMS 60mm Gauges. You guys can check what's the RRP of these gauges from the website.
Item(s) available via the group buy: AMS gauges.
This group buy will just be series 2 gauges as series 1 gauges have been cleared.
Price and price conditions:
Series 2 will cost $60.
Gauge Cover will cost $2
Water and Oil adaptor will cost $20
Fitting mount will be included in the box when you buy a gauge.
Product features:
2.5" STEPPER MOTOR GAUGE
• Provides smooth operation • Very exact
• High precision & quick response • Bright LED illumination
• Precise electrical sensor • Does not require any Control Unit for use
Series 2:
Stepping motor provides smooth operation
Ignition ON initiates self-luminescence gauge
Lightning-like Opening / Closing mode
Example of Opening
Adjustable warning setting
Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup
a) Sensor disconnection check
This function reports any improper connections, broken or disconnected sensor or sensor
wire. The pointer will wave between 250 and 260 degrees.
b) Short-circuiting check
This function indicates any short circuit on the sensor or sensor wire.
The pointer will wave between 10 and 20 degrees.
Using High-brightness LEDs Illumination
Illumination color can be chosen from white, amber ,red, green and blue
Pictures:
Product List:
TACHO 0-10,000RPM
BOOST PRESSURE BAR
WATER TEMP 50-120℃
OIL TEMP 60-150℃
OIL PRESSURE 0-7kg/cm2
VACUUM 0–30 in.hg
VOLTAGE 8-16VOLT
INTAKE.TEMP 20-120℃
A/F RATIO LEAN-STOICH-RICH
Please note that the A/F Ratio gauge comes only in Silver watchcase.
Note: You guys can choose between silver or black watchcase for the series 2 gauges (except A/F Ratio, which only comes in Silver watchcase).
NOTE:
For those who are interested, please let me know:
- what gauge you're interested in
- your color choice for series 2 (Black or White watchcase)
- Your LED light choice
https://www.sau.com.au/forums/topic/232703-group-buy-60mm-ams-gauges-3rd-round/
i might be interested but it doesn't look like any one else is lol
Just throw your orders in guys.
I will try to get the amount up as fast as possible but I need people to throw me their orders.
Waiting time is an average of about a month from now.
will try to get the gauges in by end of September.
So do not worry and just throw your orders in. :banana:
Cheers.
Any chance you could get these gauges in 52mm with blue LED?
And does boost gauge come in PSI at all?
Hey mate, the 52mm gauges are still in the manufacturing process.
the boost gauge only comes in BAR.
let me know if you're interested.
Cheers.
Guest
