I found this to be helpful.
http://www.nissansilvia.com/forums/index.p...howtopic=185697
I just did mine the other day, the wording in the guide is a bit tricky for where to loop the lines. But when you look at the pics it should make sense.
Another good idea while you got all the stuff out is to run a power steering cooler, the standard cooler is just a loop of alloy pipe near your ac canister, kind of useless, just hacksaw them off to run a cooler.
Follow the guide you should have no problems.
https://www.sau.com.au/forums/topic/232793-hicas/#findComment-4086901
