Hey guys..
just a quick question, i know there have been alot of posts about the hicas light problem but none seem to answer my question.
I have owned my r32 89 skyline for about 5 or 6 months now and had no problems until just the start of this week where i start the car up and the hicas light stays on for a few minutes of driving, but each day i drive it it takes longer and longer to go off.
i dont have an aftermarket steering wheel at all and only thing i can see is wrong under the hood is one of the belts (i think power steering belt) hasnt been put on properly and a quatre (width) is hangin off and shredding a little bit so that will need to be replaced but i not sure what is causing hicas light to come on..
any suggestions?
https://www.sau.com.au/forums/topic/232795-hicas-light-prblem-r32/
so where exactly do you refill this oil??
Check your Power Steerting fluids at the front. The bottle just behind your airbox / pod.
Then check the bottle in the boot. Its on the Right Hand side as you face the boot and you can unscrew 3/4 bolts to remove the panel.
Top it up with power steering fluid.
That's for ATTESSA & AWD - nothing to do with HICAS & steering.
Back to the problem - how old is the battery? It could be that the battery is taking longer and longer to be recharged after starting.
im going with powerstearing fluid is low (the one behind the airbox, as my car has the exact same problem (small leak in one of the hoses that im changing next week) gets longer and longer for the light to go off until i top it up.
when my battery is low the hicas light pulses and stearing wheels jerks around
