Hey all,
I just got a heap of stuff installed into my 33 GTR.
One of which was a Power FC and controller.
When i look at the controller it reads different to what the standered tacho and speedo reads.
Its around 5 to 10 kmph on the speedo and around 500 in the revs.
Which would be more accurate?
Which would you trust??
https://www.sau.com.au/forums/topic/232801-what-would-you-believe/
Are you 100 % sure on that?
Because id like to keep my shifting under say 7500 to 7000 revs.... and going by the power fc im only changing at around 6500.
And if the fc is wrong and the tacho is right i dont want to let it get around 8000 revs!
If it is the gauges i dont mind. it can stay like it. i look at the power fc most of the time... just making sure thats all.
Will the power fc be as accurate when i put the bigger wheels on? as i know thatll throw out the speedo but will it throw the fc to?
Can I expect this to be the same with my Turbo timer for speed?
up to about 60km/h they are the same but over that and the speed shown on the timer is less than the speed shown on the dash..
I have tried re-calibrating the timer but doesn't seem to help.
The tacho / speedo are basically mechanical displays, and are subject tto inaccuracy through wear-and-tear.
The FC / TT are electronic, and not subject to wear-and-tear.
I would trust the electronic display ahead of the mechanical display.
are you weary of letting it rev to 8000 for reasons of unnecessary engine wear and tear/failure, or because its not power productive to rev it so high?
the stock rev limit is 8000 or so?
I ask as i used to take mine up to 8000 quite frequently, and then a valve guide broke.. related?!
Mine is rev limited at 7000 stock.
my two speedo's used to match up almost perfect. Then after power loss (don't know why, but stereo & TT lost all memory) I could not calibrate the TT which is what leads me to believe that it is wrong?? The power loss has happened twice in 12 months, the first time it calibrated fine, the second just won't work. Any help?
as for bigger wheels, get lower profile tyres and they remain the same size. if u do go bigger i think it is just a minor adjustment to correct the speedo. (just what I was told at the tyre shop a few yrs ago)
i only keep it below that cos of unnecessary engine wear ... but thats just me... i dunno might be safe?
my dash is out aswell, using a consult (group buy lcd consult thing) shows my rpm lower than the dash, yet the same as my automotive multimeter. there old cars now, as stated above the mechanicals in them wear out.
Same with mine.
RPM and speed read lower on my AVCR than on my dash.
Because the AVCR is digitally displaying an electronic signal, it can't really be wrong unless a sensor is giving an innacurate reading (in which case both will be affected)
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
