yeah ive read that heaps of time, that putting in a metal shim style headgasket will give you better compression to run more boost. How much boost would u be able to run with metal headgasket and std internals? or even better how much in say an RB20 :D ?
  • Replies 105
Im assuming the reason so many RB25 owners often run thicker/aftermarket headgaskets is so they can dial in a little more boost as the lower compression ratio starves off detonation.
RB20s already have a lower compression ratio of 8.5:1 (vs R33 9.0:1) meaning that it isnt as common to see RB20s running thicker head gaskets in the quest to run more boost.
Im actually considering upping my compression ration if my engine needs rebuilding.:bahaha:
bbenny, its hard to say, just gotta get the car on a dyno and see what happens. Tuning, fuel, intercooler. plugs, etc - all make a bit contribution to how well the engine will handle boost.
On the subject of power to boost, a guy I know was getting around 230rwkw with the same turbo on an SR20 at 1.2bar.
1.3 bar was 240
1.4 bar was 250
1.5 bar was over 280,
so I am hoping for good things as the turbo gets up around the 1.5bar mark - time will tell.
bbenny, dont worry about dropping the compression ratio, or fitting a thicker head gasket.
My thoughts are the less boost you can run to make your required power the better.
For an RB20 i dont see 1.3-1.4bar being too much a problem on the street, as long as
- You stick to the factory rev limit (with your 2530, perhaps think about dropping it to say 6,800rpm)
- Your fuelling, engine cooling etc is keeping up.
- Proper care is paid to maintenance.
I say on the street as you are never really afforded the opportunity to sustain high engine loads for long durations.
If venturing out onto the circuit, i would wind a little boost out of it.
Lowering the compression will bring detonation higher in the rev range and thus you should be able to wind up the boost more without detonating in your car's rev range. But lowering the compression is also going to make off boost performance worse. So there's a tradeoff, like most things.
Steve, has the power curve been fixed up now so that power increases in a nice smooth fashion? Will be good to see the results at 1.5bar when the turbo is most efficient. When are you getting the head gasket done? You going to do cams too?
EVO, I am doing cams at the same time, I have 256/8.8in and264/9.0ex so hopefully will take car of the off boost response side of things. The crazy thing is, at the moment off boost is so much stronger than with the stock turbo its amazing. I put this down to a decent set of headers (tuned lenght, ceramic coated) and I am not sure if the front facing plenum is helping too, all up it is awesome. The car is just bloody awesome to drive, just wants to go hard:)
I may have to go a larger turbine housing if it starts to choke the top end, but I am keeping my fingers crossed.
Paul, cheers mate, so how is the GT30 coming along? I have decided that you guys will need to have a bbq when you come over for the drift day. Are you driving over? Would love to check it out:)
    • Just to close off this post with the cause of my oil consumption issues. Vertical scoring and glazing at the bottom of cylinder 6. I'm not happy, but at least I finally found something. I'll pull it and get it apart asap. Hopefully I don't need to go one size up in piston.
    • I finally got around to purchasing an actual articulating borescope. Great tool to have, I've been very impressed vs my old regular inspection camera.  With that being said, sadly I finally found the cause for my oil consumption. I always had the feeling something wasn't right but compression and leak down tests were always perfect and I had already inspected the cylinders. This time i dropped each cylinder to its absolute lowest point and with the better quality camera I found this... Bottom of cylinder 6.  Scoring looks deep and I'm presuming oil getting by caused the glazing. I already spoke with my assembler, and will be dropping it off as soon as I can pull the motor and get it apart. I'm just hoping it's not deep enough to require boring out from 86.5 ->87mm. Pistons aren't cheap.
    • I think it's the same. It all comes from the same shithole refinieries in SE Asia.
    • I was referring to the final octane level achieved once 10% ratio of ethanol is added.
    • E10, by very definition, has 10% E in it.
