  • Replies 105
Not too sure Joel, HKS dont have cores, they are a standard garret item - HKS only have proprietry on the comp and turb cover and compressor wheel.
I think it would be more likely to have something to do with turbine AR and comp wheel trim - bigger turbine AR will flow more, but will take longer to build boost, bigger comp wheel will flow more, but if too big could (in theory) result in a miss match to the turbine and result in surge. Always a trade somewhere.
The reason I said it was because he originally said he had a 0.68. I would like to know the exact spec differences to give a better idea of the comparison between the two. Without knowing all the specs, it would be useless comparing;)
At the end of the day, the only true way to compare would be on the same car, cos lots of things can make a difference. I noticed a considerable loss of power when I swapped my N1 exhaust for a nismo dual muffler one.
My big problem at the moment is that I want to try a bigger turbine AR, as I feel the 0.61 is maybe causing a bit too much back pressure. It is interesting that the HKS 3037 kit for RB25 uses a 0.87 AR. Might be worth giving it a try, but at well over $500-$750 a pop for the housing, I am not going to rush out and buy the full range to see the difference:D
Steve: I now have a .81 A/R Ex Housing and noticed a large difference in detenation(spelling?) levels. In my early stage I had the same tuning, same turbo specs apart from the bigger A/R ex housing and my detenation levels reduced by 1/3. I have put this down to less back pressure, less heat , and less cylinder back filling on cam overlap. Obviously my turd is no were near standard now.
The spool up difference from .6 to .8 A/R was hardly noticable. Smoother maybe.
Great results GTS-t VSPEC!! Wow, it really seems that the GT30 turbos are responding well on the RB25s. 270kW@wheels on 13psi is a $#!T load!! :) Sure you'll be having traction problems. The only problem I see with comparing dyno figures is that they can vary from dyno to dyno. Also depends on the air temperature of the day. For example, the JUN s15 equipped with T88 (in Perth I think) produced something like 700rwhp on one dyno, only to get 550rwhp on another dyno. Something like that anyway, I read it in a Fast Fours mag. Anyway, point being that there is a difference between all dynos. To compare two cars you really need to dyno both on the same dyno on the same day. In the end, it's really how fast you run the 1/4 mile which is going to judge how quick your car is. Still, very impressive figures to both! ;)
I think most companies use the Dyno Dynamics dyno (?). Very nice results, will be interesting to see how the turbo fares as the boost is increased. It does seem to produce more power than Steve's HKS one, but it also seems to have more turbo lag. Maybe there is a noticeable difference between the Garrett and HKS turbos afterall?
Once you guys start increasing the boost, then we should be able to see what happens. I've heard that HKS turbos are more efficient at a higher boost level (eg 1.5bar), and that they spool up faster. I've heard that Garrett turbos are more efficient at lower boost (eg 1.0bar). Guess time will tell...keep up the good work!!!
Steve: Do you know what are the differences between an HKS turbo and a Garrett turbo? I heard that the cores and turbine trims are the same. The only difference are the compressor housings and compressor trims. Are the exhaust housings also different? Or is it in size where they are different? Example: I know the GT3037S can have a 0.73A/R exhaust housing, and I don't think the Garrett GT30 has the same size?
The reason I ask is because I have a broken GT3037S turbo. It has a damaged turbine wheel and I am going to try get someone to repair it - either GCG or Garrett in Sydney. If the turbine wheel is replaced with a Garrett turbine wheel, could my repaired turbo still be classified as an HKS one? Meaning that the turbine wheels are the same for both Garrett and HKS GT30 cored turbos?
Thats the thing I am thinking, back pressure with a turbo is the big killer, and I am a bit worried with larger cams, therefore more overlap, things could get worse rather than better.
But if you reckon there is bugger all difference in spoolup time between 0.6 and 0.8, I think I might have to speed up the swap.
Smoother onto boost would be good, cos at the moment its bloody violent. I tried upping the boost to 1.2bar on the previous tune and holey fark, 120kmh - 4th gear and only 1/4 to1/3 throttle and the bloody thing got severly bent out of shape, thank god no cars were beside me.
RS500, if it were a 0.73, or maybe a 0.87 ( but I think I would have to give it a spin first) I would be tempted.
But 1.01, now why would you be trying to off load that??????
EVOIV, as far as I know HKS have proprietry on the housings and the comp wheel, which is why no one can buy them except HKS.
As far as I know, exhaust wheel and cartridge can be purchased direct from garret, or be ordered in by your local turbo shop.
Anybody out there got a 0.73 or 0.87 3037 turbine housing they want to off load:D
Steve: As you know, I have a GT3037S in bits at the moment. Compressor and Turbine housing, and core. The exhaust housing is a 0.73A/R. I am still not sure what I am going to do with this turbo. I do want to get it repaired eventually, if I can get my lazy ass into gear :P Also, not sure if it can be fixed - it will have to go to GCG or Garrett first for an inspection. But hopefully it can be as I think the turbine wheel is the only damaged part. If it does get fixed, I may opt to put on a larger turbine housing (sourced from where I don't know?). So then the 0.73A/R might be up for grabs. Maybe I should buy the 1.01A/R of RS500? :)
i might be lining up a buy off a friend for a GT3037 with a 1.01 exhaust housing, so if i get it, i'll swap ya no probs
yeah, if this works out and i sell my current turbo, i'm ready to move into the ball-bearing world :P
    • Just to close off this post with the cause of my oil consumption issues. Vertical scoring and glazing at the bottom of cylinder 6. I'm not happy, but at least I finally found something. I'll pull it and get it apart asap. Hopefully I don't need to go one size up in piston.
    • I finally got around to purchasing an actual articulating borescope. Great tool to have, I've been very impressed vs my old regular inspection camera.  With that being said, sadly I finally found the cause for my oil consumption. I always had the feeling something wasn't right but compression and leak down tests were always perfect and I had already inspected the cylinders. This time i dropped each cylinder to its absolute lowest point and with the better quality camera I found this... Bottom of cylinder 6.  Scoring looks deep and I'm presuming oil getting by caused the glazing. I already spoke with my assembler, and will be dropping it off as soon as I can pull the motor and get it apart. I'm just hoping it's not deep enough to require boring out from 86.5 ->87mm. Pistons aren't cheap.
    • I think it's the same. It all comes from the same shithole refinieries in SE Asia.
    • I was referring to the final octane level achieved once 10% ratio of ethanol is added.
    • E10, by very definition, has 10% E in it.
