Rob77... the exhaust housing you use on your TD06 be it 20g/25g will have a huge influence, just as it does on the HKS turbos. (or any for that matter)
Your using the 16cm exhaust housing which as you know is huge. Swap it for the 10cm like mine, or even 12cm like Trust recommend on the RB25 and the turbo will be alot more responsive.
And beg, borrow and steal and get a Trust manifold if you can, they are worth every cent as they make a measurable difference.
Steve and others are making great, responsive power with HKS turbos, just like some are with Trust turbos.
I think moral of the story should be dont sell your Trust turbo short. How responsive would a 3037 with a 1.01 exhaust housing be on a stock RB25
  • Replies 105
If I changed the exhaust housing to a smaller one I wouldnt make as much HP would I, on such low boost? I think I will change the manifold, but I'll go for the same design as gtst-vspec, a tubular one with steam pipe and then ceramic coated. This way I can keep it low mount and looking relatively stock to the untrained eye :) As for me saying its a lagmonster, I was poking fun, I dont think 4600rpm for full boost is that bad, it would be nicer quicker and I think its achievable if I do the ecu and the manifold... as I said give me about 5 weeks and the ecu should be in :)
    • Just to close off this post with the cause of my oil consumption issues. Vertical scoring and glazing at the bottom of cylinder 6. I'm not happy, but at least I finally found something. I'll pull it and get it apart asap. Hopefully I don't need to go one size up in piston.
    • I finally got around to purchasing an actual articulating borescope. Great tool to have, I've been very impressed vs my old regular inspection camera.  With that being said, sadly I finally found the cause for my oil consumption. I always had the feeling something wasn't right but compression and leak down tests were always perfect and I had already inspected the cylinders. This time i dropped each cylinder to its absolute lowest point and with the better quality camera I found this... Bottom of cylinder 6.  Scoring looks deep and I'm presuming oil getting by caused the glazing. I already spoke with my assembler, and will be dropping it off as soon as I can pull the motor and get it apart. I'm just hoping it's not deep enough to require boring out from 86.5 ->87mm. Pistons aren't cheap.
    • I think it's the same. It all comes from the same shithole refinieries in SE Asia.
    • I was referring to the final octane level achieved once 10% ratio of ethanol is added.
    • E10, by very definition, has 10% E in it.
