Item: r33 gtst series 1 1993 model Black
Condition:
hail damaged body
everything else in good contirion
Price: various just pm about the part you want
Contact: PM
Comments:
no motor no box
everything else there
most panels hail damaged
https://www.sau.com.au/forums/topic/232857-wrecking-r33/
hey mate
any interior pics?
stock steering wheel? condition?
just put up...you just chasing wheel?
Whats the damage for the rear calipers ?
Cheers A .
not sure please make offer through pm...what they worth?
what type of rear coilovers and how much mate ?
no rear coilovers?
Hey mate,
Any chance that the boot and drivers door aren't damaged at all?
Also, would you be interested in selling the boot lock?
Thanks,
Ben
boot is very damaged (apple sized hail)...drivers door suprisingly is that bad as you can see in pic...
https://www.sau.com.au/forums/topic/232857-wrecking-r33/#findComment-4085523
What sort of front bar does it have, is it the same as the one in my sig, if so im after that, the grill (especially if its black) the bar reo and the rear wing, give me a price with postage to vic 3200 and some pics of everything mentioned.
Thanks.
Edited by W0rp3D
https://www.sau.com.au/forums/topic/232857-wrecking-r33/#findComment-4087997
i wouldnt mind the passange tail light assy how far up the coast are you
near lismore ballina
Is the rear wing in the picture still alive? Or did the hail get that too? How much if its still breathing? Send me a PM please.
rear wing is cracked from hail but easily repairable
https://www.sau.com.au/forums/topic/232857-wrecking-r33/#findComment-4109748
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
