http://mallala.com/
or more specificallly, taken from:
Calendar page
August
Sunday 3rd G1 Drift Competition
Saturday 9th Practice - Cars and Karts
Sunday 10th Porsche Club Sprint
Saturday 16th Motorcycle Ride Day
Sunday 17th M.S.C.A. Sprint
Friday 22nd Practice - Cars Only 10am
Saturday 23rd SCCSA Car Races
Sunday 24th SCCSA Car Races
Saturday 30th Café Racers Club Races
Sunday 31st Café Racers Club Races
September
Saturday 6th Practice - Cars and Karts 10am
Saturday 6th Drift Practice 5 pm
Sunday 7th E.V.O/G.S.R. Club Sprint
Saturday 13th M.S.C.A. Twilight Sprint
Sunday 14th Kart Racing
Saturday 20th Motorcycle Ride Day 10am
Sunday 21st Porsche Club Sprint
October
Saturday 11th Motorcycle Ride Day 10am
Saturday 11th Drift Practice 5pm
Saturday 18th Practice - Cars and Karts 10am
Sunday 19th Kart Racing
Sunday 26th M.S.C.A. Sprint
Thursday 30th Practice - Shannons Nationals
Friday 31st Practice -Shannons Nationals/Trucks
November
Saturday 1st Shannons Nationals and Supertrucks
Sunday 2nd Shannons Nationals and Supertrucks
Saturday 8th G1 Drift Final - Twilight - Presuming you meant next Drift Competition?
Sunday 9th Kart Racing
Friday 14th Practice - Cars only 10am
Saturday 15th SCCSA Car Races - Twilight
Saturday 22nd Phoenix Club Motorcycle Races
Sunday 23rd Phoenix Club Motorcycle Races
Saturday 29th Mallala Officials Day
Sunday 30th Porsche Club Sprint
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
