Item:
NITTO extreme drag
275-40-R17
semi slick tyres
for use on GTR or similar.
Condition:
70% even - no camber/toe use
Price:
$400 o.n.o.
SA Adelaide
Contact:
1. 0432 224 954
2. [email protected]
3. PM
Comments:
highly regarded tyre in japan and for good reason
https://www.sau.com.au/forums/topic/232903-4x-275-40-r17-nitto-70-sa/
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
