My car has been over Transport inspection pit and I was provided 2 weeks to repair these "jack/jack stand battle scars" to maintain the manufacturer rigidity
I saw somewhere on this forum that someone make brackets/panel for these things so that I can just weld them on top of this bent chassis. The search is down at the moment and not very useful.
Does anyone know where I can get them from or what else can I do to fix this issue?
I now know why there is so much love for the Transport inspector. I've been asked to fix up a few other minor issues too like replace a missing plastic part behind the door open lever, enclose and vent a dry cell battery in the boot etc etc. However PLEASE please keep this thread healthy and constructive :(
Edited by 9krpm
First off, those aren't jacking points. The jacking points are under the side sills. Or use the gearbox mounts. The chassis rails are very soft in compression, as you can now tell.
Take the car to a crash repairer. They can probably fix it in a day. Couple of years ago, cost me around $250 to have one side fixed.
Thanks blind elk. I know they are not jack point but the jack points are usually collapsed in most skylines because of age or overservicing :) The transmission mount is too far back to use for the hoist as most of weight of the r32 is at the front. The engine subframe is too far forward for an asymmetric arm hoist. So that point is often used by workshop to lift/jack the car :(
I have access to hoist and welding machine. Is there any DIY fix?
Also how did the crash repairer fix your?
Edited by 9krpm
I used a big allan key and was able to massage some of the dents out :blink:
The metal is a lot softer than I expected. There are few more dents all the way at the front that is quite difficult to reach...I may need to call a dent master to come out.
I am really keen to know how your repairer remove those dents blind_elk
Hi 9krpm - We had this repair done not too long ago at a crash repairer. What they did was weld a long lever to the area needing to be pulled out. Lifting the lever with a lot of force pulls the metal out. The longer the lever, the easier it will be for you. When the rails were straight, the lever and welds were removed and the rails painted with black rubber paint. The rails are dead straight now and look like new - I was pretty imprressed. Hope that helps.
Mine failed pits the first time around for the same reason, plus a host of others.
Remedy for the amount of damage that was done was to cut away and re-box the chassis rail.
  • 1 year later...
time to revive this topic
I'm currently looking at getting this fixed on my car which looks in
pretty bad shape, is "cutting and re-boxing" a safe option, any legal
issues?
Would rather get it pulled straight using the fore-mentioned technique with lever
anyone care to add any suggestions or reccommend a trust worthy panel beater
in brissy??
My rails were re-inforced with ~4mm steel plate across the bottom and the outer, plus a bunch of other steel work. This was part of a fairly major rust repair - the car was farked when i brought it into the country.
I can now jack my car from virtually anywhere along these rails. I usually use a trolley jack with a thick lump of rubber on it to help it grip and not damage the por-15 rust proofing paint i used on the entire underside :domokun:
cutting out the bent rails and replacing is actually the best option and believe it or not you can actually buy those parts new from nissan! you can buy the new chassis rail pieces and take them and your car to a smash repair place and have the old bent rails cut out and the nice new rails welded in place.
best bet is to go into a smash repair you trust and ask them what method they'd prefer. the new rail pieces were not that expensive. under $200 from memory.
I can now jack my car from virtually anywhere along these rails. I usually use a trolley jack with a thick lump of rubber on it to help it grip and not damage the por-15 rust proofing paint i used on the entire underside :rofl2:
How much did the rail enforcement set u back??
brilliant tnx Richard, didn't realize that was an option, now to find part no and quote :domokun:
I was lucky to have a local repairer who's a TAFE teacher and delighted in doing something different for a change. $250.
I believe he used a die to thread the hole and pulled it down.
Tyrepower at such 'n such a place dropped the car off a jack onto the rail - stupid idiot.
  • 3 months later...
Sorry to go digging for an old thread.
I have been looking at a few R32s recently and most seem to have some dents in the chassis rails under the car.
But how much is too much? Couple of examples below.
Are these safe and would they pass roadworthy? If not can they be repaired? What's would be the approximate cost (in Melb)?
Thanks guys.
Don't worry about it, I went around a few workshops in the area with photos of rails under various cars and got some very useful feedback. Highly recommended if you're considering buying.
Make sure you look out for 'ripples' between floorpan and the chassis rail, it's a good sign of a compromised rails. Being crushed by jacking is not necessarily as bad, although that may be expensive to repair too.
Cheers
Solution for the long term is to ditch your $50 supercheap trolley jack and get one with a decent sized plate and rubber on it. That way you are apreading the weight over a larger surface area of the rail and less likely to bend/crush it. I jack mine up on the cross member usually but if I need one whole side up I go off the rail, I;ve never had this issue.
i wouldn't mind the 4 mm sheet metal bent into rail shape. i have been told that panel beater's remove the spot welds to get it out, hammer and dolly it straight then reweld.
Edited by Dan_J
Most damage is caused from forklift drivers in japan when they pick the car up for shipping
The forklifts driver should be kicked in the balls by everyone on SAU
Edited by NISSAN GTR
  • 2 years later...
i know this is an old thread but i have been stressing since i bought my 32 after seeing the rails and have wanted to get it fix,now i know its possible . So anyone know a workshop in brissie that could do the job,or even better someone that has had it done resently with good results. Thanks
    • Don't "upload" the pictures. Just copy the picture direct from somewhere (I usually am pasting screenshots or something else that I have on the clipboard as an image, not as a file" and just paste it direct into the post editor. Just like you were pasting it into a Word doc or something. You can't damage something if you lift it where you are supposed to. If you look carefully at the correct jacking points, you will see that they are reinforced right there. And nowhere else. That is where the "foot" of the factory jack is supposed to sit. That's why you need rubber pads with slots. 10mm might not be deep enough. Note also that the slots are not required if the pinchweld has already been slammed flat. You could just lift it at the correct spot with a flat pad, because the damage is already done. No point in making worse though, if it is recoverable. IF. Yes, that's called a chassis rail. You can lift carefully on these, if you spread the load. A decent block of wood is good. But keep in mind what I said before. Any time you start doing this sort of thing, you are off the normal path and into "be bloody careful", because it is obviously not stable. Dumb. The refinforcement is already there. See above.
    • yeah looks like they've been lifted there previously but with solid not slitted rubber blocks. I'd just bend them back (combination of vice grips or hammer with some sort of drift, then hit the area with underbody protection paint. As for the siderails, I'd call those chassis rails and that is exactly what I meant about being careful with the balance point. You can probably lift off them at the point where the 2 pieces overlap, but you need to be careful with the forward balance of the car if you do when the engine is in....sills are a better choice. I guess you could weld some reinforcement in the sill area near the jacking points but it shouldn't be necessary if you use blocks with a slit. If you do want to reinforce it I'd use square section equal or taller than the seam and then just use flat rubber blocks for lifting
    • driver side sidemember and jacking point (looks the worst by far) driver side rear jack point passenger side sidemember and jack point passenger side rear jack point   Ignore my mug on the last photo. Turns out I was just too stupid to properly use the forum's attachment feature previously
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
