I ride a Dobermann Pinscher, the paintjob on my frame is a little pitted due to perspiration and general non-maintenance.
I'm planning to bring this bike over from singapore, is the pitted paintjob and issue to the quarantine people?
  • Replies 1.1k
ok so
kinda thinking of getting a 2nd bike to go with the alias
not exactly sure if i'll do it or not
but... toying with the notion of getting a designated road bike,
the two im looking at are, CRX....
and the Bowery Mashup
crx-one hammers freaking hard as a road bike, however, it has too many things in common with the alias, and if it has too much in comon with the alias then i worry i'll favour one bike over the other, plus the mashup is a single speed, therefore it's a completely different ride to the alias and is therefore no threat to the alias... plus i think the bowery mashup looks fuckkinngggg hot
wat you guys reckon?
how much you like the bowery will depend on whether you run the freewheel cog or the fixed wheel. fixed wheels take a fair bit of getting used to as the pedals turn whenever the wheel does. this means no jumping gutters etc unless you are extremely talented. however doing wheelie's backwards certainly impresses people.
depending on how flat it is around where you ride will also determine how much you like the bowery. only having 1 gear means that it will be ok if it is flat, but if it is hilly you will have a bit more trouble.
and you say that having the bikes too much the same may mean that you like 1 more than the other, having 2 bikes totally different may mean that you hate 1 and love the other and may not want to ride 1 at all. at least if they are similar the amount that you prefer one over the other won't be much. and it isn't like you are using them for 2 completely different things, like 1 for cross country or downhill and 1 for road where 2 completely different bikes are what you need. you are pretty much using them both for the same thing.
it'd be an freewheel SS, i dont see what the purpose of everyone having fixies is!!!!
and, basically, it's flat with a few hills all over the place, small hills but hills none the less, they're a challenge
this is my thoughts
alias
versatile
technological
gears
shocks
discbrakes
"lazy" (can change gears at a hill)
mashup
simple
compact
purpose built for speed
challenging ride (better for fitness maybe?)
like yeah, both bikes ARE being used for the same thing, BUT, the difference is "i'm feeling lazy, i wanna use gears/i wanna go trails riding" or "i feel like a workout and am going to a cafe and want something that looks trendy parked next to my soy-a-cino-latte"
also, do these bikes go FAST? the net says they're built for NUTSO speed however when it est rode one it seemed similar speed to my alias? if they go fast then i'm pretty much sold come tax time!
too lazy to change usernames,
your top speed will be slower on a single speed than a flat bar road as the gearing is made to be at a ratio that gives a mix of low gearing for climbing and higher gearing for on flats/down hill.
flat/down hill speed you will be quicker on the alias because you have taller gears that you can change into to go faster. more so on the down hill rather than flat.
the crx you will be faster uphill, flat and downhill than the alias.
because they are different. basically they are just a big bmx with small bars. they are a trend. they sell because they are different, not because they are good. just like girls who wear those stupid big sunnies. they buy them because it is fashion, not because they actually look good.
or it's like an iphone....... LOL
hmm.... and i am definately 100% the kind of idiot that falls for this stuff.. and i won't lie, i still want it haha
...i more want it for fitness.. like it's ride position and the fact that if you have to ride up a hilll for a while tough shit you gotta deal with it...
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
