  • Replies 1.1k
  • 3 weeks later...
Couple of updates:
New rubber:
Duro Leopard
Front: 26x3.0
Rear: 24x3.0
New saddle:
all 2nd hand off Rotorburn. :P
Marc do you have any suggestions for seating the bead on a tire? The front is being stubborn.
i'm guessing that it is a tight fit? there is only really one way. pump it up until it pops into place. if you get to 100psi and it hasn't popped yet, let the tyre back down to about 15psi, try and pop it out a bit by hand (to do this you have the bit that isn't sitting in place facing towards you then grip the tyre and try to roll it off the other side of the rim) then pump it back up again.
i am only using 100psi as a guide as it depends on what the max reccommended pressure of the tyre is. if the max pressure is only 60psi then you wouldn't want to go much past about 80psi. however if the max pressure is 90psi then you can go to about 130psi (although it will usually pop out about 110psi).
you can also try wiping a few small amount of washing up liquid around the bead of the tyre before pumping it up this will make it a little bit more slippery and pop into place better when it is pumped up
Just got my first road bike on the weekend for $100
The brand is Xtreme and it's pretty much new
popped both tires on the first day cause the outer said 100psi
and the inner probably couldn't take anything over 80
gonna be hitting the Centennial Park tracks every weekend
to see if I'm fit enough to do the Syd-Gong MS ride :P
pretty sweet hog for the price... dunno if i'd do sydney to gong on it myself though!!!
marc - what's your take on "slimes" i got a pair the other day and i'm very unimpressed with them =( only fitted one, not happy at all so returning the other today and swapping for just a regular tube.
i'm glad you onlt paid $100 for it, cause i certainly wouldn't have paid anything more for it. that isn't entry level. an entry level road bike is worth about 5 times what that is. probably the cheapest, nastiest road bike on the market (since it is a supermarket bike), and that's why you would've popped the tubes. the tubes should take higher pressure than most tyres. they tyres are what determines the pressure. tyres with weak sidewalls won't take much over about 90 to 100 psi (when rated to 60psi) before they tear the sidewall apart. a tyre rated to 100psi will take up to about 140psi before it starts to tear. also cheaper tyres punture much more easily due to lower density casing. and they are heavier.
just have a look and see where the punctures occur. often on those cheap bikes it will be on the inside because they have used a thin rubber rim stip and the tube buldges into the spoke holes and creates a thin spot which then pops.
personally i think that any road bike that doesn't have intergrated shifters (shifters in the brake levers) is a waste of time. that bike would be much heavier than any other road bike, and more than likely be much more uncomfortable to ride as well as a rougher ride. you would've been better off paying another couple of hundred and and gotten something a bit older but much better quality. if you plan on doing long rides expect to be having to replace the wheels in a few months after the hubs shit themselves. also if it is a 6 speed (can't tell from the pic) and the freewheel isn't a shimano one, immediately take it to a bike shop and get them to fit a shimano one. it will save you being 20km from home and have the freewheel pack it in and leave you without any drive (you will pedal but the wheel won't turn).
sorry to rain on your parade, LOL
rowan, not a big fan of slime tubes. they often don't seal the hole up until they have let most of the air out of the tube, and after a while they just don't seal it up at all.
yeah nah got rid of the slime tube - the shop let me swap it over for a hutchison one...
and yeah - that bike will be suitable for riding to the shops and such, but for actually riding long distances ie syd/gong... no... if you can do it then that will be awesome
infact
i'll fedex you a can of coke!
you will only get road tubes with presta valve (french valve). yes there is an adapter to make them a car valve. they should only cost a dollar or 2. they are a brass adapter that screws on.
as for good tubes, pretty much any tube will do. with those tyres, don't go for any lightweight tubes. go for somthing like CST, innova, maxxis, tioga, etc. basically any brand from a bike shop ecxept swallow. they are shit tubes, LOL. something like the michelin airstop butyl are a good tube. not too thin and made of better quality rubber.
  • 3 weeks later...
they aren't a bad tyre. and at that price you can't go wrong. unless you do lots of kms on dodgy roads. then make sure to carry lots of patches or get a tyre liner. tyre liners are good things. we run them in cherie's bike. my tyres have them built in.
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
