  • Replies 1.1k
i will say that my new cannondale's frame doesn't feel as BULLETPROOF as my giant...
that said
it's a track frame for "road" intentions (but realistically it's just a trackbike with pretty colours)
it's not built for being thrown at walls and dropped out of planes
so i think being that it's only going to get speed and road treatment i think it's a good purchase
fyi - i now have the capo - and it's FKING fast!!!! if there's no wind it's easy to get it up to about 55/60odd km/h if you're down on the drops - i can't remember a time i've travelled that fast without a downslope
so
while i won't say the frame is as tough as the giant
i WILL say that the bike weighs 7kg. and goes like a rocket on rohypnol
and that's what it's designed for =)
and don't bother changing the cassette - it's a DH bike!!! unless you're using it for commuting distances... if that's the case then yeah go for it ... but i would also consider changing the ratio and getting another 8speed - that's what im doing with my dad's bike thanks for the advice marc!
i know a guy who has gone through about 6 road bike frames. snaps the bottom bracket out of them. he doesn't treat them rough, he is just a very strong sprinter. he has used pretty much every major brand and still keeps braking them. it is just a simple fact that there becomes a point where light = weak. at the bottom of the market lighter will usually mean stronger because better materials are being used, but once you get to the top of the market (and in some brands only halfway through the market) they start making them too light. a mate of mine who owns a bmx brand ended up making his frames about half a kg heavier (went from 1.7kg to 2.2kg) and then offered lifetime warranty on the stronger frames because all the lighter prototype frames snapped.
ok so here is a bit of a list of some of the more obscure bike parts that people either don't really know or get mixed up.
bottom bracket: the part of the bike that the pedals attatch to, located at the bottom of the seat tube. this can be both the shell (the part of the frame) or the bearing, etc. some bikes use a cartridge system (bearings and spindle/axle are all in 1 unit), others will use seperate bearings from the spindle.
seat tube: the part of the frame the seat post/pillar goes into.
seat post: the bit the seat clamps to
seat post clamp; the clamp on the frame to stop the seat post moving
seat clamp: the part on either the seat or the seat post to clamp the seat to the post.
head tube: the part of the frame the forks go into
top tube: the top..... errr tube that runs from the seat tube to the head tube
down tube: runs from the head tube to the bottom bracket.
chain stays: run from the bottom backet to the rear wheel
seat stays: run from the top of the seat tube to the rear wheel
dropouts: the piece at the end of the chain/seat stays and at the bottom of the forks that the wheels go into.
steerer tube: the tube of the forks that comes up through the head tube
head set: the bearings that go in the head tube
head stem: the stem that goes from the steerer tube to the handlebars (often mixed up with head set)
rim: the outer rim of the wheel. this does not include the hub and spokes. if you are talking about the rim, hub and spokes, that is the wheel.
freehub & cassette: some wheels use a cassette gear system (8 speed and above, and some of the older 6 and 7 speeds). this is where the cogs slide onto a part on the hub called the freehub body. the freehub body has the freewheel/ratchet mechanism built in to it 9slightly different design on bmx's). this makes the axles stonger.
freewheel: this is when the cogs and ratchet mechanism are all in the one unit and they simply screw onto the hub.
brake levers and calipers: brake levers are the bits on the handlebars, the calipers are the bits that move the pads against the rim/disc
where's your bell? $30 fine for not having a bell when riding on the road
true story
lol
Bell fines... I'd get raped if they caught up with me considering the BigHit has no reflectors, bells, lights, etc on it.
Been meaning to get a honka-hoota for racing though. :thumbsup:
haha my c-dale came without a bell - is that a paddlin on the bikeshop?
i removed my bell from my other bike on account of nobody gives a shit anyway if there's a pedestrian in your way there's about a 99% chance they're listening to the kings of leon on their ipod anyway and can't hear it
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
