I had a profec b spec2 EBC installed a couple of months ago and the display would always show "-99" reading when the engine was warmed up and idle.
I was told that this is very good because it shows that the compression is good ie. engine has not been trashed.
Now all of a sudden recently, I have noticed that the ebc's display shows the vaccum around -85 instead (when warm and idle) after a major service during which all belts were changed (excl. timing, which was done earlier) oil, etc
The weird thing is, on some days the ebc displays -99 or so when warm and idle and other days it just won't go below -87
What could this mean? Has there been some damage to the engine??
I'm using thicker oil (10W40) after the last service to stop some valve lifter tapping noises .. car seems responsive and as before but I'm worried something's gone wrong with the engine somewhere.
Also I noticed that if the idle warm vaccum reading is -85 or so, when I press the clutch in it goes down to -90 ..and back to -85 when I let the clutch go.
And another (possibly related) thing ... my belts were squealing badly (too loose) after last service so I took it to a local mechanic who I think may have overtightened them .. could this in any way explain the vaccum thing??
Edited by Delta Force
https://www.sau.com.au/forums/topic/232967-vaccum-change/
the EBC is in PSI mode ... what worries me is why suddenly the ebc displays -85 when the engine is warm and idle when it used to be -99. That's exactly one 6th which makes me think that something might be wrong with one of the cylinders?
https://www.sau.com.au/forums/topic/232967-vaccum-change/#findComment-4085852
https://www.sau.com.au/forums/topic/232967-vaccum-change/#findComment-4085853
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
