Back From Japan
maximumrpm
 Share
hey all
just got back from japan last week and saw a few r35 gtrs over there. Most were in outer osaka and saw one in tokyo too. Didnt see any in the nissan show rooms at all :)
ive attached a pic of one i saw in shinsubushi area
Is that anywhere near Shinsaibashi?? lol
I am leaving Tokyo this evening, and I did just alittle better....
I actually took this Black Premium edition for a spin :):)
It`s been said a thousand times already and having owned prior generation GTR`s from the R32 to the R34. what Nissan have created with this car is not a new model...it truly is a new benchmark...
What really amazes me about the R35 is how un-photogenic it is...... I think its looks fairly average in the thousands of pictures we see day in, day out - Let me tell you guys, the car in the flesh is astonishing...and the sound of it...its honestly comparable to the RAW sound of a Ferrari 360.........as for the performance...well...that needs another thread :(
Enjoy
I actually took this Black Premium edition for a spin :):D
What really amazes me about the R35 is how un-photogenic it is...... I think its looks fairly average in the thousands of pictures we see day in, day out - Let me tell you guys, the car in the flesh is astonishing...and the sound of it...its honestly comparable to the RAW sound of a Ferrari 360.........as for the performance...well...that needs another thread :rolleyes:
Enjoy
Sorry to come across as sceptical but the rental place ( which i can tell it is from the photos ) just let you loose in the R35 with an international license...?
On another note, the car doesnt sound anything like a ferrari.
There is afaik only one rental place in tokyo that lends the R35 and you have to be a platinum member and have held a Japanese license for a few years...
NO...IT IS NOT A RENTAL PLACE - it is in fact the rooftop of the Nissan Dealership of Nissan Tsumada, in Kanagawa-Ken, just off Route 129 - no need to draw conclusions without foundation. I have better things to do in life than to pull people's legs and 'claim' that I have driven one without having done so. Like I said, the rawness of the engine IN MY EYES has a rawness comparable to a Ferrari - if you feel otherwise, good for you. I didn't just turn up to a Nissan dealership and demand a test drive - having lived in Japan for over 3 years some time ago, and with a current business partner who is a close associate of the owner of that dealership, it wasn't a difficult request to ask. Next time, keep your sceptical BS to yourself.
Adam obviously didn't see the "Nissan High Performance Center" badge on the staffs overalls in the 2nd pic :(
Thats what i thought it was a first glance.
I wasnt expecting scepticism to be met with such vehemence, lol.
Everyone knows i made up all those stories anyway. :(
I went to Jamboree at Willowbank raceway on the weekend and saw the new R35 Gt-r skyline up close, they are an awesome looking car and go hard as well. It ran 11 seconds and that was just standard! :D Apparently the guy wasn't allowed to drive it in Australia as they aren't approved over here yet, shame really they would be a really nice car to drive. :rofl:
 Share
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
