Item: DoLuck front bar
Age: 1 year old approx
Condition: second hand, very good
Price: $250 ono
Comments: front bar is in great condition, no stone chips and at the moment its in white primer, it was on my car and it looked tuff, but i got over it now and im after a gtr bar. ne way it has only been cut out where the cooler pipes were and thats it. its a perfect direct fit i was very impressed when me and my panel man put it on.
Item: 25mm wide front fenders
Age: over a year
Condition: very good, only 2 slight cracks in one gaurd which remained there wen i bought them
Price: $200ono, i paid 330 for them.
Comments: i did have the guard fitted to my car for a few days wen it was off the road but i took them off as it was going to cost me to much to get sprayed, i jst left da originals. i fitted them my self there was a bit of trial and error but they sized up quite well unlike others i have seen where there an inch to short, lol. they do have holes drilled in them so they will fit in all places where original guard fit. i dont have a pic with these on the car sorry
Item: R32 gtr spoiler
Age: who knows
Condition: excellent
Price: $125ono
ALL ITEMS
To Fit: R32 gtst
Contact: 0421 357 455
    • Yeah. I believe the fear of annealing the alloy and weakening it, Every online discussion has someone saying it's bad and potentially a risk when powder coating forged wheels.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
