  • Replies 74
Posted Images
hey guys. awsome ill have the video on the laptop tommarow, so il send them all to those people who gave me there emails.
thanks guys niran
Niran if you could flick the footage through to me as well that would be fantastic.
[email protected]
Cheers
Hey every one. i have sent the video to every one. i was un-able to upload it to people because my hotmail's maximum limit is 10mb. so i uploaded it to photo bucket, and because people didn’t want every one to be able to view the video ( as in you tube ) i made the file private and put a password on it. if any one else wants me to give them the video just send us a email and I’ll forward the link and password.
Thanks again guys have a good one... Also I’ll start uploading all the cruise videos on here from now on.
Cyazz
hey guys, thats no problem sorry it wasnt to long. from now on i'll try get more footage and cut out any hooning parts and post it up on there. i'll also try get some photos..
have a good one guys, niran
Edited by niran
Ahh.. i bailed to the Midland Leg.. i lost the pack.. then i got lost myself.. haha. Didn't really wanna rush the orange then it turned red light hehe..
Had a bit of a squirt wif R34GTR NUR @ the lights.. I let him go 1st cuz i didn't know where the next turn was haha
-SeS
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
