hey guys...
i just brought a skyline and its a 32. dont know much about it.. just want to get some advices from some skylines experts..:)
My car has been running rich and miss firing. so i took it to the mechanic the other day for a compression test....the mechanic said it might be the coil packs, apprently the guy i brought it off done some pretty dodgy jobs on it..so yea.. well my friend had some spare R33 series 1 coil packs, so i chucked them on and brought a new coil harness as well... everything was fitted nicely and all but its still missing firing and when the car revs up to about 3000 revs it just doesnt boost anymore:( just wondering what other problems it could be..all i can think off it would be the spark plugs.. and if i change the spark plugs myself do i have to gap them.. from what i heard was when u changed the spark plugs u need special tools to change and gap them.. thats all..
thanks guys.. if you could give me some advies i will be much appreciated ay:)
cheers:) nick:)
hey guys...
cheers:) nick:)
Hey buddy, try changing your fuel filter and/or checking the flow rate of the fuel pump.
If you don't know how to do that, start with the fuel filter change and see if you get results from that. I would say 99.9% of skylines I see with a low rpm hesitation or missfire is caused by fuel system problems, coil packs usually don't give a missfire until 5000rpm or around abouts.
revs to about 3000 ? if it was around 2800 or 2900 i would be thinking its going into limp mode
exactly what mine was doing (faulty AFM) so i ditched ecu and bought a vi-pec ecu so i dont need afm's anymore
cheaper option for you would be to try a afm off a mates car and see if that fixes it then you know to go and buy a new afm
20's run 1.1mm gap standard. The reason people gap the plugs down is usually because of increased boost. A lot of people are running coppers gapped to .8mm. Personally I'm running the factory platinums gapped to 1.1mm at .85bar without any problems, but i do have splitfire coilpacks. It's best to run the biggest gap that you can.
Can't edit post. But in relation to the topic it sounds like a fuel miss not a spark miss. Get a new fuel filter from Nissan P/No. # 16400-53J10 and check your fuel pressure with and without the vacuume line going to the fuel pressure regulator.
yeah def faulty air flow meter, i had the same problem,
if u got a friend with a r32 or r33 series 1 only, swap with him and see how it goes,
thats wat i did and found that was my problem
also, re-gap spark plugs to .8mm or so for increased boost,
i couldnt run more than 10psi with 1.1mm and found out regapping helped alot,
lol now im running 17psi on a 480hp turbo
  • 4 weeks later...
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
