Hey just my car from the compliance show and when they said it was in very good condition I believed just that, fact is i'm overseas at the moment so didn't have the chance to see the car to justify the condition. Anyway girlfriend just informed there are numerous scratches and dents as tho a car has scraped the whole driver side plus scratches all over the bonnet, boot, rear numberplate and god knows where else. From the detailed pictures I got from Japan it had to have been done in transit or at the compliance centre. Just need to know how to go about this, am obviously extremely pissed off at the moment and need advice. Its looking like a complete respray for a car that was in perfect condition before it left Japan.
https://www.sau.com.au/forums/topic/233018-trashed/
Did you have shipping insurance?
If yes go through them. I had pics of the car sent to the insurers from the dock in Japan, and then once it got here just to cover my self. If you don't have pics and it's been in Aus for a few weeks it may be tough, but try it anyway.
https://www.sau.com.au/forums/topic/233018-trashed/#findComment-4086688
Word of advice for anyone thinking of importing, be there for every part of the transportation process from the docks thru to compliancing to just before it leaves the compliancers. Due to me being overseas at the moment it will quite possibly affect the outcome with insurance for the damage done, not being able to follow it up quick enough.
Does suck big time not being able to do much but will definately be trying to sort it all out when i get back, will keep you updated on how it all goes.
https://www.sau.com.au/forums/topic/233018-trashed/#findComment-4105979
Mate that is the risk factor you have to consider when you import cars , ive imported many cars let me tell you they dont always look like it the photos in saying that i imported some very clean ones. Did you import it yourself or an a Import agent in Australia ?
https://www.sau.com.au/forums/topic/233018-trashed/#findComment-4114217
Yeh I did go thru an import agent, isn't the first time i've imported either so I knew the risks that came with importing. Biggest hassle is the photos taken before it left Japan were fine,with the marks I knew displayed on the pictures, problem being the scratches have suddenly appeared so i'm guessing it happened during transit somewhere, it only being aesthetic is a bonus as thats the only problem. Apart from a few minor things extremely happy with what I got.
https://www.sau.com.au/forums/topic/233018-trashed/#findComment-4114364
Hi,
Any update on your situation?? Just hope everything has worked out fine. I know the feeling when something like that goes wrong.
Thinking of importing a V35 but starting to think about buying one locally.
I was going to import. I chickened out and bought one locally. 99.9% go well from what I can see but i have the luck of the Irish or lack thereof.
Works a treat when it goes well but I didn't have the money to gamble on a slight chance it would go pear shaped.
I too hope that the situation here pans out for the good. Let us know mate.
https://www.sau.com.au/forums/topic/233018-trashed/#findComment-4154201
Been stuffed around heaps trying to find out who knew anything about the scratches, at the moment it seems hopeless but do have a few contacts I can get in touch with at the gold coast who can do a repair for me. Found a few scratches on the wheels and just wondering if anyone knows of any good places to get them repaired (Brisbane/Gold coast area).
https://www.sau.com.au/forums/topic/233018-trashed/#findComment-4156053
Mark,
To fix up your wheels, speak with Chris at Wheels Revolution, Slacks Creek.
Due to the color of the coupe wheels, its gonna set you back close to $200 per wheel to get the scratches removed and the whole wheel repainted to factory color.
https://www.sau.com.au/forums/topic/233018-trashed/#findComment-4156224
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
