Id love to see one of those racepace conversion kits. The site is flash, but relatively painfull to visit.
I spoke to Alex at Plazmaman a while back and all his plenums are designed on a flow bench. I cant imagine then that the flow is rubbish.
there is more to manifolds than flow, think of a manifold as a sub box (theory wise) and you will be far closer to producing a quality item.
Race Pace; 9762 9421 Factory 9 no.6 Hollway Drive Bayswater 3153 (Top workshop)
plazmaman use factory runners which are fairly long aswell i was trying to steer cleer of the long ugly runners
thanks guys im thinking jun copy plenum chamber and custom runners might be the trick
ill let you all know how well it works (before and after dyno results)
thanks
keeps ideas coming if you have any others
I had the whole mission of choosing the right manifold to due to my piping getting in the way of the stock one.. after to talking to heaps of tuners, mechanics, fabricators etc, I found that having the standard runners is the best for response down low - the short runners supposed to be awesome for top end but will make the thing a dog down low, especially with the 3540.
The guy that tuned my car was saying that the Plazmaman one as it is so large would obviously flow awesome but wouldnt be the best for low revs and quick spool they are a large volume plenum - basically the turbo has to make the boost to fill all your piping plus the large plenum. So it is a bit of a catch 22 and you have to decide what you want from it. Moral of the story is, its basically like an exhaust on an N/A car, if its too big the thing will have shit acceleration but scream in the high revs, if the exhaust is smaller, you'll have the pressure down low to get good response but the theing will be restricted at the high revs.
When I did mine I didnt want to or really think of buying an ebay copy and modding the runners so that is why i went the Plazmaman, looks neat in the engine bay if you match the finish right + has the long runners for down low + the good flow for making the thing go crazy later on.
Edited by ThirtyThree
i am in the process of looking for a new plenum and intercooler kit. THinkin bout going the full kit from Plazmaman. $2875.00 is alot of cash. Do any of the guys on here have any dyno results of fitting the said plenum to a rb25det. That would be great. Cheers
Check my website www.ripsracing.com in the products section, there's some pix there of a few of our plenims.
I have one of our latest R33 RB25 plenim kits in stock, its the type we use on all our street and drift motors and we've had very good results.
I can ship within hours of payment and the full kit with plenim, new billet 80mm throttle body, cable, fittings and gasket I'll do for nzd1300incl shipping.
Look here for pix of the actual kit and other things we've made recently,
http://www.gtr.co.uk/forum/104094-r-i-p-s-...abrication.html
Rob
god dam all that stuff looks great. God work. Now will you be able to make a plenum the same for a rb25det but to fit a r32 engine bay. Does anyone know if the engine bays are the same size. I am not sure even if i order a greddy or plazmaman kit if it will fit in the engine bay.
With the plenum from NZ Rob do you have any dyno sheets with before and after or any proof of the results. Would be good to see. Cheers.
That plenim will suit a R32 body and its to suit a R33 type RB25 head, I presume thats what you have. I have plenty of pix of them in 32s, if you want to see them e-mail me [email protected]
I havn't done back to back testing from stock with no other changes but we've had real good results with these plenims and all the drift guys with them comment on the response etc.
I have done a 8.7 @ 162 in a street car and one motor we did recently made 620whp at 1 bar on 98 pump and 960whp at 2 bar with C16 with the same trumpet design and a slightly bigger plenim body so there is no question they are fine for performance as well.
Rob
Edited by R.I.P.S NZ
theres some ppl here saying the stock runners r best for low down...so can u just get say the top half of the greddy plenum n fit it to ur stock runners?
No such thing as a top half greddy plenum. It's all in one and replaces everything in the stock setup, runners and plenum.
i guess thats the question rips, do you do a 26 setup to suit 25?
if so how much?
and how would it compare to your current 25 plenum in terms of overal performance across the board?
Edited by dangerman4
Its nzd1100 for a GTR plenim, 6 pack, throttle linkages and a RB25 base modified to take it all if we supply everything.
If you want to send me the lower 1/2 of your plenim deduct nzd200.
Its not a 5 minute job to do it nicely and there's a fair bit of welding and porting involved.
We've done a few of them and they seem to respond really well.
I suppose it comes down to the look your after as much as anything but I suppose theoreticly you'd get slightly better response from the 6 pack with GTR plenim but not alot of difference up top.
Rob
Rob
That is good value Rob $900.00 NZ exchange. Will the modified plenum and runners take the top feed, or side feed injectors.
all of ur work looks awesome rob!!!!
i would love to get his stuff eventually!!!!!
especially...
for my r33. wat would be the price for both units?
thanks and keep up the amazing work!
Jaye
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
