  • 2 months later...
  • Replies 42
http://www.hitechmufflers.com.au/contact.html
Is this the hitech you used? I want to get this exhaust happening on my gtr as well, very impressed.
Nah, i dont think thats them. Im pretty sure theyre in Bathurst. Same name though; maybe it is them, but they just have their factory in Bathurst. My exhaust guy is away, so i camt find out atm.
Shaun.
No i dont. Im hopeless with computers too, so i doubt i could figure it out. Maybe i could take a vid of it with my digital camera, and upload it somewhere. Im just hopeless with converting files etc; i dont understand that at all.
Ok, ill check for you as soon as i can.
If you want to check the exhaust out, im sure we could arrange something (if your in or around Sydney that is). Im in Gosford.
Ill still check for you, but im sure the Hi Tech in Sydney and Bathurst would be the same company.
Shaun.
I gave them a ring and there factory is in bathurst, s i think they are the same place. If you can check some time it would be greatly appreciated as im going to do the same setup as your car.
No worries. Ive got the diff out of the car at the moment, so the exhaust is on the bench. If you need exact measurements of the centre muffler let me know. Ill be putting it back in on thursday.
Shaun.
Oh no rush man i dont plan on doing it tomorrow or anything, also im in adelaide but thanks for the offer :P
Hi Shaun, pics and dimensions my way would be brilliant also mate.
Ok, Ill have them to you by the end of the week.
Im pretty sure i mentioned that the wastegate was venting to atmosphere when i had the car tuned. I dont think it would make any difference if it was plumbed back in though. Ive since made another front pipe that plumbs the screemer in, and ill put that on this week.
Shaun.
Edited by Shaun
Sirracer and GTR1993, ill just post the info here rather than send seperate PM's.
The dimensions of the Hi Tech made centre muffler are: 305mm long x 220mm wide x 150mm thick. As you can see from the photos, the design is centre in and offset out with perforated tube through the middle. The offset is towards the passenger side of the car.
The specs and product code of the rear magnaflow muffler are in my first post.
I dont think there is any more you should need to know to order the same custom muffler from hightech, but dont hesitate to ask if there is.
These are old photos, so i can take some new ones tomorrow when my exhaust is on if you like.
Shaun.
*****EDIT***** Make that offset in/ centre out in design, with the offset towards the drivers side of the car. Sorry; i had it around the wrong way!
Ill take some more photos tomorrow so you can see if there is more room around the mufflers if you want to go bigger. With the way the US dollar is at the moment, maybe Magnaflow wouldnt be the most cost effective option. I think mine was about $330 (exact price is in first post), but that was when the dollar was about 0.94. It might be worth getting two custom mufflers made from Hightech. There is heaps of room around the rear muffler.
Shaun.
Edited by Shaun
I actually bought 2 magnaflow mufflers the other day (the center muffler im using center in center out) and they were $310 each! Im going to try this if its no good ill get the custom one, but i had the car int he air and should fit fine.
Thats a good price for the two mufflers. Were they the same as my rear one?
Im no expert, but i think you might find that its a bit loud, as the centre offset muffler gives really good noise supression. Ive run my car without the rear muffler (with only the centre custom job in), and it wasnt that much louder than with the complete exhaust on, which i found suprising. If youve still got twin turbos it may not be too bad though.
Anyway, you'll be able to sell the muffler for a good price if you find that you dont need it.
Shaun.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
