That PPG set is not a synchro box. It's dog gears. Just so you know, Pete. :)
Hi Paul, sent off for some info, dog gears, sequential gears they would be like ridding a bike again and that is OK but I guess they are crappy for DD use.
Saw a Video with a bloke in a parking lot and not having fun at parking , so I guess they can be a pain.
Just said to Joey that I might just get the build done with what I have and see what happens or give it a miss :)
On my laptop now so I cannot PM you.
Pete
I'm running 450kw at wheels on e85 through a stock box, previously at 410kw went to the drags, no issues
Another drag night coming up on the 16th July
Should hold up, box doesn't crunch or anything might just be lucky
Your in the zone now, just a matter of time.
Would you be happy with a dog box or sequential box in the car?
I think if I was going to do either I would have to drive them but the sequential sounds , well interesting and I would love to try it, maybe not buy it,haha
Thing is, everyone seems "ok" with the gearbox "constantly" failing.
Is it not a big deal to get it rebuilt?
Is it worth going for smaller turbos (-9/GTSS) to specifically avoid this weak point?
Second hand boxes are pretty cheap $600-$1000. And only about $1k give or take to rebuild depending on what's smashed.
Less power is not an option once you've been there.
  • Like 1
Broken boxes being a big problem and magnified when using 3 and 4 plate clutches,so I will ditch the Quad and going for a Twin, but what Twin to use on a torquey R34GTR.
There are a few that were recommended to me..Coppermix C Spec twin seems to be on the top of the list.
What about carbon types?
  • Like 1
Pete,
Jim Berry full monty with organic plate works for me in 26/30 GTR 350rwkw @ 6250 but then I don't 'launch' so may not suit your needs.
Back OT I spoke to Award about gbox strength recently, their view was that a good margin of failures occur due to:
'nut that holds the wheel'
downshifts rather than upshifts
Pete,
Going with the Super Coppermix Twin Plate Clutch, done enough looking my head is going to fall off and have had some great help from some of the blokes on this site :)
I guess I am going to be that NUT and loving it.
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
    • I used to love going to Amaroo to watch the HQ series go for broke (eventually stopped due to lack of spare parts) and also the Porsche series.  It was so cool to back your car up to nearly the edge of the viewing barrier and party with your friends, having a bbq and alcoholic/non drinks. It was such a family/mates atmosphere
