She's going good. Pretty much anybody can drive the car now. This clutch is just so easy to drive compared to some others.
Hi Richard, you have the Super coppermix C twin?
I found as my mods started to give the car some torque/response, the OS Giken Quad clutch became much easier to use as a DD and I have no doubt it will be even better after the stroker build BUT from what the blokes have said that have a similar set up, I would be nuts not to get a quality sprung twin clutch that will be more forgiving on the box.
I will have to think of selling off the leftovers, the RB26 block, the motor mods and clutch have only 3500Klms, forged internals etc and I do not want to bring any of them back home with me. So once I know what is coming off I will go to the for sales thread.
Yeah your heading down the right track in regards to clutch etc.
I just changed from an OS giken triple , just like your quad. It destroyed more than half a dozen gearboxes including 2 OS Giken gearsets. I loved the feel of it and had no problems driving it, but anyone that just hoped in to have drive did struggle a lot!!
Hopefully the sprung centre will be the difference and help the rest of the driveline.
Yeh , had a few blokes talking up their driving skills and I gave them a drive when I first got it home, they could not get it going to get into second, made me feel a bit better after my drive home from Sydney when I bought it,1 1/2 hours in peak hour traffic,F, it was less than a fun drive in your new car,haha
The OS triple was an expensive exercise for you :( but I guess you were giving it heaps and loving it at the time :)
My Quad is OK as a DD now with the changes I have made but from what the boys have said and what you have experienced I would be stupid not to have the clutch changed while I a having the build done.
Trouble is now I have to wait to get it done :(
Low ten :D
When did you last bleed your 4WD ?
Pete Paul has a build thread
Here http://www.skylinesaustralia.com/forums/topic/397676-piglets-rebuild-of-his-busted-tomei-28/
I also not sold on spring centres in high powered 4WD, twin plate yes sprung centre not so much :(
I do it every 10k, it is fairly easy to do when you have seem it done, with the power you have use Trans max Z or even RP Syncro max in the transfer case and the Matic D in the ATTESA
Paul, its to do with how the spring setup works and how hard the springs are, the spline rotates inside the clutch disc with only the springs there to stop it, now this is fine if the springs are strong enough to absorb the torque but if not them the spline will rotate till the springs bind then the box takes the brunt of it if the clutch can't slip and by the time the springs bind the clutch is already engaged :(
Tougher springs?
Makes sense... But where is "the limit"?
Thats why I not sold on it, cause I have no idea how far you can go with it before it becomes a potential problem, I know I feel happier with the I sprung triple in my 34 then I would a sprung one, I know I felt it with one of the single plates I had in the 32
I am very doubt full all the springs are identical, then that might be the torque rating the clutches have is referring to ?
Tuffer springs or extra plate ?
So IF the springs aren't strong enough to absorb the shock, then it would be the same as unsprung? Wouldn't it? No better, no worse?
What's wrong with Matic-D ? Ive never had any issues with it. Whereas when I tried some others that were recommended they didn't handle it ( boiled I think )
Depends how hard it hits the wall ( spring binds ), at least with the unsprung clutch you can slip it till its loaded up fully, but hitting the spring stop would be like slipping your foot off the side off the clutch pedal while its on the floor boards giving the sudden jerk, again this is just one of my crazy theories and no real proof of it and would depend on how hard you are over powering the springs
Matic D is basically dextron III, not exactly same but very close, where Trans Max Z and RP Synroc max are designed for higher then normal loading like towing a caravan and stuff and while you don't have any issues with it and most likely never will I like the idea of having something designed more for what I'm doing with it
Low ten :D
Thanks Mick, been having a look, lots going on in there, I think I will croak before I finish reading it all,haha
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
