She's going good. Pretty much anybody can drive the car now. This clutch is just so easy to drive compared to some others.
Hi Richard, you have the Super coppermix C twin?
I found as my mods started to give the car some torque/response, the OS Giken Quad clutch became much easier to use as a DD and I have no doubt it will be even better after the stroker build BUT from what the blokes have said that have a similar set up, I would be nuts not to get a quality sprung twin clutch that will be more forgiving on the box.
I will have to think of selling off the leftovers, the RB26 block, the motor mods and clutch have only 3500Klms, forged internals etc and I do not want to bring any of them back home with me. So once I know what is coming off I will go to the for sales thread.
Yeah your heading down the right track in regards to clutch etc.
I just changed from an OS giken triple , just like your quad. It destroyed more than half a dozen gearboxes including 2 OS Giken gearsets. I loved the feel of it and had no problems driving it, but anyone that just hoped in to have drive did struggle a lot!!
Hopefully the sprung centre will be the difference and help the rest of the driveline.
Yeh , had a few blokes talking up their driving skills and I gave them a drive when I first got it home, they could not get it going to get into second, made me feel a bit better after my drive home from Sydney when I bought it,1 1/2 hours in peak hour traffic,F, it was less than a fun drive in your new car,haha
The OS triple was an expensive exercise for you :( but I guess you were giving it heaps and loving it at the time :)
My Quad is OK as a DD now with the changes I have made but from what the boys have said and what you have experienced I would be stupid not to have the clutch changed while I a having the build done.
Trouble is now I have to wait to get it done :(
Low ten :D
When did you last bleed your 4WD ?
Pete Paul has a build thread
Here http://www.skylinesaustralia.com/forums/topic/397676-piglets-rebuild-of-his-busted-tomei-28/
I also not sold on spring centres in high powered 4WD, twin plate yes sprung centre not so much :(
I do it every 10k, it is fairly easy to do when you have seem it done, with the power you have use Trans max Z or even RP Syncro max in the transfer case and the Matic D in the ATTESA
Paul, its to do with how the spring setup works and how hard the springs are, the spline rotates inside the clutch disc with only the springs there to stop it, now this is fine if the springs are strong enough to absorb the torque but if not them the spline will rotate till the springs bind then the box takes the brunt of it if the clutch can't slip and by the time the springs bind the clutch is already engaged :(
Tougher springs?
Makes sense... But where is "the limit"?
Thats why I not sold on it, cause I have no idea how far you can go with it before it becomes a potential problem, I know I feel happier with the I sprung triple in my 34 then I would a sprung one, I know I felt it with one of the single plates I had in the 32
I am very doubt full all the springs are identical, then that might be the torque rating the clutches have is referring to ?
Tuffer springs or extra plate ?
So IF the springs aren't strong enough to absorb the shock, then it would be the same as unsprung? Wouldn't it? No better, no worse?
What's wrong with Matic-D ? Ive never had any issues with it. Whereas when I tried some others that were recommended they didn't handle it ( boiled I think )
Depends how hard it hits the wall ( spring binds ), at least with the unsprung clutch you can slip it till its loaded up fully, but hitting the spring stop would be like slipping your foot off the side off the clutch pedal while its on the floor boards giving the sudden jerk, again this is just one of my crazy theories and no real proof of it and would depend on how hard you are over powering the springs
Matic D is basically dextron III, not exactly same but very close, where Trans Max Z and RP Synroc max are designed for higher then normal loading like towing a caravan and stuff and while you don't have any issues with it and most likely never will I like the idea of having something designed more for what I'm doing with it
Low ten :D
Thanks Mick, been having a look, lots going on in there, I think I will croak before I finish reading it all,haha
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
