Hi Guys, I need some help here before I tell my story.
I had a dash cluster which was faulty with the odometer and trip meter.
When it was at 89999kms and 350kms, it stopped running. This cluster is for an R33 Automatic S1 car.
Fair enough, I went to buy a used dash cluster, from a wrecker. That guy told me that IT IS TESTED AND IT IS WORKING BUT THEY WILL NOT WARRANTY IT. This dash cluster is for an R33 Automatic S2 car.
so I swapped the dash cluster, took out the Airbag light bulb and everything is working well but........now I have a problem:
The speedo is reading way out. It is reading approximately more than 2x speed of what I am actually driving. I know this from the GPS reading. Therefore let's say I am driving 95km/h, it shows that the needle is out of 180km/h...to about maybe 220km/h and the car starts to vibrate (like stopping me to go more) but the everything is working
when I called up the wrecker....
he asked me to go find an electrician and doesn't want to exchange the speedo for me.
R33 S1 = only 6, PESL are joined...[the solder point doesn't look genuine]
R33 S2 = 4, 5, PESL are joined... [the solder points seem genuine, not done by anyone]
both of them with 180km/h face.
now I want to use the S2 speedo.......what should I do?
if anyone of you know an auto electrician in Brisbane please let me know the address and number (pm will do)
i called up one...he said he doesn't do imported car "too troublesome" wtf
I did search, so far no one has solved this.
https://www.sau.com.au/forums/topic/233059-speedo-reading-r33-s1-r33-s2/
I have the same problem but mine is the opposite. My odometer stopped working so i bought a new cluster from a wrecker, swapped the odometer parts and tried it out. It works fine but it shows half the speed im actually doing. ie when im going 60 it shows 30. I have a S2 manual and the replacement cluster i got was from an automatic, but i dont know if it was a seried 1 or 2 but either way its not working. Any help would be much appreciated.
Pretty certain that you can return them to the seller (wrecker). Under the Trade Practices Act, the item must be "fit for purpose" - clearly it is not if it can't tell you within a reasonable level of accuracy how fast you are going, which is its designed purpose.
Warranty only covers "faulty" ie doesn't work at all.
Yeah it would make sense for us to swap but firstly we are in different states, and obviously the km's would be different. I took mine back to the wrecker and he said he would swap it anyway, im sure you should do the same Joon. I did think of that Terry, it just goes back to that old saying of easier said then done.
Hi traum,
the speedo which I got is for an automatic car tho, I am just afraid it might not be suitable for manual but I am not sure in this matter.
to clarify whether you are holding a S1 or S2 dash cluster, difference is S2 will have a vacuum meter inside the rpm meter.
your speedo is reading half of what it should?
I got this info from one of the forum poster here, credit "gumflapper"
"On the back of the speedometer circuit board, there are a number of solder points in a row labelled "Adj". There are 10 solder points labelled 0 to 9. The solder points, when not "jumped" are seperated by a small gap.
To calibrate the circuit to read a maximum speed of 300 km/h, the points labelled 3, 4, 5, 7 & 8 need to be "jumped" by applying solder to bridge the gap for these solder points."
here is a few things might be able to help you
1) get the cluster, unscrew the 4 screws behind the dash cluster which are surrounding the white round thing next to a "black mid-finger"
2) go back to the front, gently remove the speedo by pulling out...gently.
3) check behind
there is a list of number under ADJ
1~9 PESL, check which one is soldered and could you post here again and let me know
whether your dash cluster is for S1 or S2, auto or manual, and which point is soldered.
my S1 speedo for an automatic works, only point 6 and PESL are soldered.
if you can probe the speedo, the frequency might be
the wrecker [ALL AUTOMTIVE IN SEVENTEEN MILES ROCKS] doesn't want to exchange his faulty product, he accused us because we had touched it and tried to altered it. he said he can sell one for 50 just the speedo and he will take this dash cluster back.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
