Hey guys!!
My names Kate, I have been given the nickname of Drift Barbie due to my blonde hair and pink wheels and helmet!! i own a 1993 R32 Nissan Skyline.. have had her for a couple of months now and have some pretty big plans for her!
The 32 runs an RB20det which im selling to upgrade with an rb25det! I currently have Drift Barbie stickers along the sides of her also Import Master's stickers along the back panels! The engine has a few mods, the usual fmic to4e turbo blah blah blah..I've put a screamer on her which definitely makes her stand out!
The car is white at the moment but i have recently been sponsored by Westside Panel and Paint and they are going to paint my car for me so it will be a BIG change!
My goals are to one day be the best girl drifter in Australia! I really want to race Drift Cat!
so thats pretty much me in a nutshell
if you ever see me out at the track dont be to scared to say hi or give me a wave :(
https://www.sau.com.au/forums/topic/233065-noobie/
As Msnizmo's car says "Barbie is a broad minded female"
I think I will sticker that onto my bike...
Paint it same colour as the donut car and new rims to match!
:) righto :rolleyes: LOL barbie is a little doll.. and if your referring me to what you said.. you have the wrong idea bro'
thank you Zilch
Edited by drift barbie
https://www.sau.com.au/forums/topic/233065-noobie/#findComment-4087361
ahh okay haha ive never seen that sticker sticker before!!
i only have the drift barbie stickers on the car now to make it stand out as all the places i drift at the moment there are about 5 other white 32's at every event i go to so i like to stand out!
also when i get it painted im putting different wheels on.. the pink wheels are old stock wheels that ive just spray painted haha!!
although i have started a thread since i painted them pink ive seen about 5 other cars paint their stock wheels pink :rolleyes:
thanks for the welcome!! although i just shat myself after seeing your avatar
gotta be one of the best old school scary movies made!! :) i almost cry when ever i see clowns haha!!
https://www.sau.com.au/forums/topic/233065-noobie/#findComment-4087394
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
