Couldnt see a thread so thought I would start one, thanks to Ash for organising the cruise today. Met some new people as with most SAU events and had a great time despite the weather. Amazing to find Lauren's parents from 20 minutes up the road from my parents place back in the UK!
Thanks to Mav for co-piloting also :rolleyes:
Will upload some more tomorrow, off out now.
A few pics:
https://www.sau.com.au/forums/topic/233079-gor-wrap-up-thread/
Great cruise!
Thanks Ash for organizing the cruise, good work.
Car felt and performed great on the road, even in these wet conditions. Big thanks to EAS Performance for an outstanding job :rolleyes: Was so happy to be behind the wheel again!
A few people with cameras, so don't be shy and post up pics :)
Well I had a fun day. Shame about the wet weather on the way home but now I can say I've at least done half of the GOR.
I'm glad I got my hands on a CB. Much better when you know what's going on. Al. Your Evo is sick.
There are some pics here. http://www.skylinesaustralia.com/forums/Go...80#entry4087187
I didn't see the wrap up thread.
photos are uploading to my gallery now. should be another hr or so till im done. been capped you see. anyway. i've played round with a few pics with the levels and contrast but cbf processing them all. my fav pic of the lot would have to be Al's headlight. came out a lot better than expected. all the shots taken on the road are courtesy of my passenger. i was too busy having fun
Gallery 1
Gallery 2
pics are jumbled too soz
Great day out :D
Pity about the weather on the way back, but oh well, nothing you can do sometimes!
Thanks for coming everyone... i must thank Aaron @ rampant & Mick @ Micolour, without thier help thurs/fri i wouldnt have been able to take my car :bunny:
Top blokes both of em!
I'm kind of pissed about this... despite having signed up to SAU Vic on 4 August, I STILL haven't been given access to the Vic club events forum and couldn't get the details. :D
Sorry Max, I've given you your access today, i didn't have a spare moment late last week.
FYI - As the Membership form states and i did inform you, please allow 15 business days for processing.
So 4th Aug + 15 business = 26th Aug.
26th Aug would be 2 days from now :bunny:
Thanks.
Ash
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
