  • Replies 50
nah, don't want to be repainting the whole side of the car if i scratch it
HAHA true true :blink:
I would never paint mine that colour, just love the look of it. Second choice for a 32 would have to be the black pearl but hard to match again for the same reason. Dam pearl colours, so hot yet so much work
pearls are easy to match just not 3 layers like whites lol. most of the 3 layers these days can be painted and matched like a normal colour. For example all the new mazda colours that are a 3 layer from the factory PPg still makes you paint them as a 3 layer but Glasruit which i use has them all as a single layer
ohk, i've picked a colour iwas going t go Midnight Purple but i saw a R32 GTS-T drive past that colour and it got me thining it might of been done to many times so i'm going with this colour (sorry about the pics it's hard to show the pearl on a small card in a photo but i looks really good and subtle)
dunno about that one mate, looks a little too pretty, but if you like it then thats all that matters. I guess it depends on what "look" you want as well. For example, do you want a show-car look, purposeful "look" or sleeper ??. I am in the same situation at the mo', trying to figure out what colour to go with for my BNR32. My personal opinion is that the GTR's are aesthetically really tough and masculine, and are suited to more neutral palletes such as Silvers, blacks, greys and white. My flavour of the week is the colour scheme of the R34 Z-spec (silver with black rims). Tough, understated and purposeful. Last week i was convinced on white. Week before i was considering midnight purple or millenium jade, so go figure, i cant make my mind up!! I may just end up leaving it in Gun Metal. :P
i'm keeping it blue cause i dont wanna do the engine bay ut if i was going to change the colour it would be going BMW moonrock, best silver out there imo.
I just want something different, dont want black as it's a pain to keep clean and this colour looks unreal on a car, we painted a VY SS ute in something like it and looked awesome
Cool. I have to say the blue is warming to me, as one of the toughest R32's (Calsonic) wears a simillar hue. I think white rims would really compliment the duco as well. :) Make sure you post pics when its done.post-38494-1220634365_thumb.jpg
yer was going to do the wheels white cause there gold atm and it look like the owner in japan was going for the WRX style which i'm not a fan of.
this is how it should look when it gets here:
was meant to be here today but has been delayed for some reason
Whatever colour you go for in the end, I'm sure you'll enjoy it heaps.
Me? I'd go Midnight Purple
...for 1 special reason besides lovin' that colour...
Nissan makes that colour so special, that anyone who sees it thinks, 'yeh that's a Nissan colour'
And if anyone wants a #2 reason... Even the hue of that colour changes depending on how the light falls on it.
Pics don't do it justice; 'cause you only have to move one metre this way or that; and wham! It's different!
:P
I just had my 32 gtst painted millenium jade.
its a really tough color but i now need to do a few more things to the car to make it look right. the thing with millenium jade is it needs a lot of black to contrast with. and orange looks dogs balls with it.
so i have done the following
rolled the rear guards over an inch
powdercoated the wheels satin black
headlights have been pulled apart and the insides painted satin black
the corner indicators have been replaced with clear ones
all trim has been painted black
darkest legal tint has been applied to windows
to finish it off it needs a black or carbon front splitter and a pair of 255-40-17 semis to go on the rear.
it should look subtle but mean when finished and i have been holding off on photos till it is all done
Sounds great, should look hot when finished. Make sure to post pics when finished.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
