Hey Sydneykid,
I was wondering how long it would take for you to bite... :P
Yes harmonics are indeed a fascinating subject. Hmmmm...overbalancing...an intriguing concept...and one that I've only rarely seen made a frustrating mention in my theoretical travels. This will no doubt occupy considerable brain time on my part. My inital hypothesis of the notion is that an artifical harmonic is induced through the overbalance, such that it destructively interferes with the troublesome primary natural harmonic at 7500RPM....
I assume you have built engines to this specification. How do they perform and survive the onslaught?
The Phantom seeks harmony from the Oracle....
  • Replies 139
It would be interesting if you could create a mirrored (180 degrees out of phase) frequency to the harmonic, with the same amplitude, and then it would be completely cancelled out.
they do this with sound, in high noise environments, so it shoud work with an engine.
Ah theory.....
The answer just hit me! a horizontally opposed 12 cyl 6 litre engine!:P
Sorry got a bit carried away.
Having been left intrigued by Sydneykids mention of overbalancing vs crankshaft harmonics I have attempted to dig deeper into theory to try to explain it or at least understand what is going on. Very little is out there on this specific subject however, with only a few good texts found at the local Uni and state libraries, explaining engine balancing and vibration theory for the various engine configurations.
Anyway, based on closer scrutiny, I have changed my mind in regard to the previous hypothesis I made regarding the mechanism wherby this is achieved...it is much more complex.
Since the crank is essentially a complex torsional tuning fork, two mechanisms exist to alter this frequency. One is material stiffness, and the other is weight. Since there is not much you can do with the stiffness, other than perhaps nitriding or some other treatment, this leaves weight. By overbalancing I can only assume added weight on the counterweights over and beyond the factory level, possibly with a heavier-than-steel tungsten alloy inserts. This would effectively lower the frequency of vibration. Theoretically at least if you double the weight you would also double the inertia. Relations show then that the resonant frequency of each crank throw would also lower by a half. The resonances are still there, but have shifted in frequency leaving the more power productive 7500 RPM plus region clear for a hammering. Ofcoarse this leaves the 3750 RPM band at a peak, but since we are probably talking full on race engines here that isn't a problem, particularly if the critical RPM is quickly passed through and that relatively little power will be made there.
I am left curious as to how the standard RB30 crank handles the lateral as opposed to torsional crank deflections at these ludicrously high RPM's. Perhaps this is the reason for the heavy crank girdle made by Nizpro on their powerhouse RB30/26 hybrid with a standard based crank. Although heavier counterweights would help counteract this, the RB30 standard crank has NO counterweights directly over number 2 and 5 crank throws. Compare this to the OS Giken 3.0 billet crank which has EVERY crank throw counterweighted an as such would greatly assist in reducing the lateral deflection. No girdle is used on this engine either, which one can only assume is because of the superior stiffness of the billet crank. These counterweights present opposite all of the crank throws are also significantly bulkier, which is in line with what Sydneykid is suggesting....and the OS engines supposed ability to reach over 10000 RPM.
This thread however began with a discussion on light weight accessory pulleys and harmonic dampers, with their lower rotational inertias and theoretical power gains. The MUCH heavier OS crank would have significantly higher inertia, but since the engine can handle such absurdly high power outputs anyway, this is obviously of secondary relevance, even in the super time critical world of drag racing....
I await Sydneykids further input into this discussion with great anticipation...
Originally posted by benm
Is it just me or does anyone else look at the above posts and just see chinese ? :D
actually, its been an interesting read, once you can translate it :D Keep up the good chat guys
Apologies for appearing to hijack your thread and moving off topic. That wasn't the intention, just thought you and others might want to learn more about a related subject in which detailed information is very rare. Even rarer is finding someone with Sydneykid's experience willing to share some of this knowledge...
:D
  • 2 months later...
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
