as topic says
i was told by a mate after i bought it that it doesn't fit just by sitting it in the boot, you need to put it on an odd angle in the spare tyre tub...
wondering if anyone has got a trick way of fitting it nicely?
thanks
perhaps be more descriptive in your question next time and you might get a more descriptive answer.
is the box you want to fit a genuine alpine box or is the sub just in a wedge style pre fab box? if you can take a picture of it.
the pre fab wedge style boxes fit snugly under the parcel shelf in a 32.
and seems you have already bought the sub and box why dont you just put it in and see for yourself lol?
theres a reasonable height difference in the space under the parcel shelf in a 32 compaired to the hight available in a 33.how much clearance did you have between the top of the box and the underside of the boot lid?
hey mate i know wat you mean. I have a r32 with a genuine alpine 12" sub box and i lied it flat and it still doesnt fit. Had it sitting in the wheel well for a bit but gets chucked all over the place. Ended up making a wooden floor in the boot and bolted it down. Its the only way to do it if you wanna keep that box. Limits boot space but if you wanted boot space then why did you buy a skyline? :laugh:
someone told me skylines where great family cars and with the high petrol prices you would save heaps with the fuel economy that you would get from owning and driving a skyline. boy did i get fooled.
Ah... I get worse fuel consumption than anyone i know. Including 5.7L V8's and SR's etc... oh apart from GTR's lol they are REALLY bad
Cant you tell its not a family car by the size and fact that 'most' skylines have 2 doors?
Anyway let me know how you decide to mount the sub as i am interested in any other ideas ppl may have...
Edited by BennettR32GTS-T
yeah boot space doesn't bother me, i just don't want it on some retarded angle and getting thrown everywhere as you said
today is the day i'm going to try and fit it so we'll see what happens, might go and change it for another brand one at JB if it doesn't fit
thanks matey
Make one yourself. A bit of MDF, some screws and some carpet.. Not hard.
I fitted a nice sized box under the parcel shelf with an angled back to use all the available volume against the back of the seat. Still gives me useable boot space. R32's don't really need a rear strut brace luckily.
So your just going to slap some wood together and hope for the best?
Its not that simple im afraid,subwoofer boxes NEED to be calculated and designed for the particular model sub you intend on using wit it.
Its like sticking a truck turbo on a little RB20,it will not perform well at all and in the end blow something up.
Im more then happy to design a box for you so you only have to follow my design and build it to spec.
Jack
I didn't say that, did bennett or mysterykid? Mine has the right volume for the sub that I had, for the response I wanted (god knows what it is cos that was a long time ago and I don't care that much about it).. just so happened to fit nicely under the parcel shelf with a bit of jiggery-pokery.
Edited by heller44
Jack88 - I already have the genuine box and i was going to measure the volume of it then make it about 10mm lower and adjust the width and depth accordingly to get the same volume. Do you really think this would affect the sound quality?
in answer to both of you, sealed boxes and generally fairly forgiving so a decrese in box volume by such a small amount wont really affect anything,you probly wont be able to hear the difference at all anyway. so you dont really have to adjust any dimentions.
yes thos type s's go pritty well in a sealed box too,for the money there an excelent sub.
Jack
EDIT are you planing to just built a whole new box or modify the alpine one? is the alpine one a sealed box or ported?
if its sealed box decresing the volume will just raise the tuning frequency a small amount which you probly wont be able to hear the difference.
id recomend building it equal in volume as the original one just to keep things the same,if your already modifying part of it you may as well do it all properly.
Edited by Jack88
    • That's f**ked up. I'd guess it's more likely that you have an entire S13 subframe in there. Does it still have HICAS mounting points? Seeing as it is quite possible that yours is the only such converted car in the world, you'll probably struggle to find someone who can tell you from direct experience. 'Twere I you, I'd be looking for 4 stud Skyline rear brakes and convert back. At a minimum. Preferably go find all the stuff you need to put it back to 5 stud (assuming you're happy to change wheels) and upgrade to some decent brakes. You don't even need much stock stuff. Don't need calipers or rotors, as you can go fully aftermarket. Just needs hubs and the other bits and bobs that are different to what you have now.
    • The engine has nothing to do with it. The physical space behind the headlight is the limiting factor. And the height. The height of the NS70 is the same as stock. So the clamp bar across the top goes on nice. The battery tray is big enough for it to sit on. The X is for extra capacity - it has even more lead in it than the non-X NS70. Heavy f**ker. But it's not a track car, so I will suffer a couple of extra kg. In the case of the R34, maybe the physical space there is not as deep (forward-backward, not up down). Hence why they say the 60 is the biggest. But I would never trust a catalogue to tell me what will fit. I have the car. I have the existing battery. I have the tape measure. I have the dimensions of all the available batteries. I find the biggest box that will go in. (With the right terminals in the right places, of course).
    • Hello! I have been having a hard time finding the answer to this question… I have a R32 GTS-T Sedan than has been 4 lug swapped using S13 hubs, rotors, and brakes. The front has also been converted to S13 suspension.    When the swap was completed, the handbrake cables were never hooked up, as the S13 rear calipers are the “handbrake”, and not the typical drum on rotor that the R chassis are. Does anyone know handbrake cables that will work for this conversion? I’d like to not use a hydraulic handbrake and stick with the traditional cable style. My original thoughts were to go with S14 cables and try to make them work, since I’m pretty sure S13 cables will be too short.    Any help would be appreciated!
    • I did some research, considering you have a neo engine, how is that battery compatible? I checked centuries website and super cheap and says it's not compatible. Only this full size one is. https://www.centurybatteries.com.au/products/ns60-mf
    • No, lets be honest here. I went to Winton and did a track day, for all the mods and V8 power and craziness I posted up a time that a K24 stock motor Honda Accord can do on the same tyres (narrower, too) 250kw and learning how to drive the f**kin thing is the sweet spot.
