so i just bought 33gtst,
mods are as follows
3" turbo back,600x400x100 front mount,pod filter,splitfire coils,walbro 255l/hr pump,hks evc2 boost control,
im looking at buying a haltech e11v2,some 550cc injectors,hiflowing the turbo and looking for about 225-250rwkw...im worried bout lag and any other probs that might show up tho so if any one can give me some tech pointers it wuld be good,please no redirects to tutorials or stickies,im a mechanic im just looking for a couple of extra opinions,and am i gonna need more then that for the desired power??
any help much appreciated
https://www.sau.com.au/forums/topic/233162-new-r33-gtst/
It's all on here, for such a common upgrade path - just search! I'd try to get a Power FC if you can, less fuss for closer to stock 'niceness' eg coldstart etc. You could probably figure out your options from all the 'what do upgrade next' threads on the first 3 plages of this section alone.
https://www.sau.com.au/forums/topic/233162-new-r33-gtst/#findComment-4087967
if u get the stock turbo highflowed it shouldnt get too much turbo lag at all. Maybe if was abit bigger then would start to lag. But the turbo size is fine for the engine so shudnt be too much lag. The smaller the less lag
https://www.sau.com.au/forums/topic/233162-new-r33-gtst/#findComment-4088988
id start looking at coilovers or heavy duty clutch. but if its purely power your after, id be going power fc as well
my main problem with the power fc is the lack of upgrades in the last god knows how long and the little "technical oversight" in the lack of knock correction,is it just the price that turns people off haltech or is there more to it??
https://www.sau.com.au/forums/topic/233162-new-r33-gtst/#findComment-4090284
Everything you have listed is fine for your goal. Like said above, if the clutch is stock then thats the only thing that will need to be upgraded.
With 220-250kw, you wont need to worry about lag at all, very similar response to factory with a highflow or T28 series turbo.
https://www.sau.com.au/forums/topic/233162-new-r33-gtst/#findComment-4090979
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
    • And, given that you're in NC, go buy an LS7 or something equally sweet and piss that crappy old RB off. Or call up Wesley Kagan and get his help putting a Merc V12 into it.
    • Do a compression test, and a bore scope on the cylinder that lost parts of the plug. Chances are, that cylinder isn't so happy anymore...
