New R33 Gtst
Are there any wiring looms that weren't swapped? Were all the dash looms changed etc?
OK, so all I can suggest is that - if you have all the parts, and you have all the wiring looms, and you have all the electronic modules, then....it really is just a wiring problem. You likely have a damaged wire, pin, etc, somewhere.
By DraftySquash · Posted
Yup, bought this bad boy and hopefully it will be ready to pickup today. Had $5 credit on top of it so it worked out really well! -
Yeah it is really until until you get a feel for it....then it is easy. Which is no use to you really. I'd buy that torque wrench. One thing from sure, many (most?) tyre shots overtighten the f**k out of wheel nuts, so don't worry if they were tighter when you tried to take them off compared to when you do them up. I've had some crazy tight ones come back from shops, quite apart from the potential damage to the thread, I can't see a smaller person taking the wheel off on the side of the road
Hey mate, thread dredging hahah To answer you directly, yes I had my itbs oversized and custom butterflies etc made by EFI Hardware in Sydney back around 2017-2018 if memory serves. My setup had a vast amount of other changes too though, so no direct comparisons unfortunately. i went from oem itbs, HPI manifold and internal gate hks 2835 pro S; to 49mm itbs, cnc port matched Nismo plenum, RB25 Neo lower runner adapter hand port matched, r31house v2 Takoashi MAX equal length twin scroll manifold with twin 38mm tial gates and a FP HTA3076 with 1.01ar twin scroll real hosing. feom power Fc to a link fury wired by 12volt, r32 gtr fuel tank conversion with frenchys twin 460 / surge tabk fuel hanger combo kit, 1659cc injectors, full 4 inch turbo back stainless exhaust, Z34 6 speed, Tomei 2way with 4.3 final drive and a ton of other shit. ive posted elsewhere here with complete run down, but here's a graph from its initial tune with no boost control on, 20psi gate springs only and e85. 7542AE72-DA92-4E0B-8660-B0940FEA7F24.mov
