i have been told previously that 9.5 18 + 22 won't fit so I dont like your chances. Test fit them though you have nothing to lose.
At the end of all my rims searching i ended up buying R34 GTR wheels at least I know they will fit and later on if I decide to lower it I wont have any issues or need to lip the guard.
yah only problem is i'd be ordering them from overseas....might have to find someone who works in a wheel shop or something cos i know most places dont really like to test fit when u arent buying rims from them.....
i'm running 18x9.5+15 on my stag - so the 9.5+22 will sit 7mm in from them.
here's a couple of pics for you to see, my guards are rolled and i'm running 235/40/18's. a shite load of camber and a bee's dick of clearance but zero scrubbage :)
and this is a 4WD height with less camber. even though they protrude, there was no scrubbage :)
hope that helps somewhat :)
alternatively, buy the wheels in my sig :bunny: - make an offer :)
Edited by M I K E
I love the look but there is no way that is inside the guard or legal, I just put on R34 GTR wheels last night and ill see if i can upload some pics to show you that there is a little room for going bigger. Up front they look about right but on the rear they look like you could fit something a little bigger.
It is an RS4S I dont know if it makes a difference
here's a couple of pics for you to see, my guards are rolled and i'm running 235/40/18's. a shite load of camber and a bee's dick of clearance but zero scrubbage :(
and this is a 4WD height with less camber. even though they protrude, there was no scrubbage ;)
alternatively, buy the wheels in my sig :( - make an offer :)
Good to finally see someone else in Australia with some balls to run decent fitting wheels.
9.5 +15 is "GTR offset", fits stags perfect up front and rear. nice work on the height as well. *claps*
18 x 10 + 20 rears and 18 x 9.5 +26 fronts with 25mm bolt on spacer to bring it to +1. Needed a lowering of 25mm front with a bit more camber and 15mm rear same camber.
stock guards, just lipped. no scrubbing.
Hahaha, AlexCim, I was wondering when you'd pop in and see this post. :D
lol yeh being parked on the steep driveway doesn't do it much justice ill get some more pics up when i get my phone back
Very nice, I have simaler offset on my 33, I also use bolt on spacers to lower the offset.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
