Hi,
I just bled my clutch because im having disengagement problems, and was wondering if i can remove this distribution (?) block that is situated in line between the master and slave cylinders. Then i could just have a braided clutch line made up that runs from the master cylinder directly to the slave cylinder. Surely this would be better for pedal feel and be easier to bleed.
Also, i wouldnt mind knowing what its for before i remove it altogether. See the pic below; its the funny black box that has a bleed nipple on it and lines running into and out of it.
Also, does anyone know of people who would make a braided line that runs from the master cylinder to the slave cylinder?
Thanks,
Shaun
yeah you can do exactly that, and it does make bleeding much easier. UAS sell a straight braided replacement for a good price, we just put one in the car today.
here's a pic of it from another thread
Isn't that block part of the clutch fluid cooler. Wouldn't removal of that block leads to overheating/boiling of the fluid?
Mine was removed when I purchased the car. I've been thinking of getting one to try and see if there is any benefit.
Shaun, don't bin that unit and make a donation by sending that unit to me :D?
nar it wont cool anything, there isnt really a flow in the clutch system, if you want to blled the clutch well with the block, i found to bleed the clutch through the slave, and then go to the block bleed it from the block, and then back to the slave,
but
i would much rather 1 line haha, but i cant because my lines are rounding the bolts trying to get them off so im just leaving it.
if you really want one I am pulling another one off next weekend. but unless you want to pick it up in syndey postage would be a killer
Shaun....MAKE A DONATION (I really want it on a faster server right now :D )
Thanks for the reminder Duncan! +1 for faster server too.
UAS sell them for $120 which isnt too bad.
Now for another question. Is it a worthwhile upgrade to get the Nismo larger slave cylinder rather than a stock replacement one? I think the Nismo ones are about $80 or $90 extra.
Thanks again,
Shaun.
  • 5 weeks later...
Thanks again,
Shaun.
i got the UAS one and all i can say it AWESOME. bleeding the clutch 5 minutes (max) i did matster, slave and cable and im never looking back. the clutch feels great and alot heavyer
I got a braided line made up from a brake and clutch place; they said it would be $60 but they forgot to charge me for it!
I've got a braided line that I've been meaning to fit but haven't yet. Was going to do it while my suspension is out being rebuilt in the next few weeks but does it really make the clutch a lot heavier? I was also looking into the Nismo slave to make it lighter as that's all it does that different to stock. Then I thought, I bet we can find a local slave the right size that will do the job. Any ideas? Gotta find the internal diameter of the stock and Nismo ones again. I had the measurements but I lost them.
Shaun, don't bin that unit and make a donation by sending that unit to me :mellow:?
Yup, it's the cooler.
Bypassed mine, and two other Skylines with no adverse affect.
Bin it bro!
well im about to bin mine, tried every bloody adjustment and 3 bottles of clutch fluid later i still cant dis-engage so i cant even get the car into gear,
apparently when you get a heavy pressure plate etc.... theres a point where you rubber hose to the slave will just exspand instead of pushing the slave out because of the pressure which is needed,
so my APP 1 piece braided line arrived today, will put it in tomorrow and i hope my clutch works, otherwise i will be cut,
(that box thing was the dumbest design ever)
Don't forget to bleed the master first, then the slave. Otherwise you'll be bashing your teddy man. I learned the hard way......
Pretty sure its not a cooler, it wouldnt work, and the clutch fluid has no reason to get hot
Yeah man it is a cooler. The workshop manual even states it.
The reason the fluid gets hot is because of compression. If you pump the pedal enough it will heat the line.
They're not use on brake lines because they run the length of the vehicle and the underbody draught cools the lines.
Anything under compression develops heat - A case in point: Turbos.
  • 4 weeks later...
How did you go with this?
I am in the same boat, except ive lost my slave cylinder in moving sheds. So I can't even take my old one is for a sample.
Apparently the difference between Std and nismo is 19.05mm vs 20.54mm, with the current exchange rate its pricing them upwards of $200. And im sure a PBR or Powermax wouldn't be more than $60.
Infact I reckon a Patrol one would do the job.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
