Hi,
I just bled my clutch because im having disengagement problems, and was wondering if i can remove this distribution (?) block that is situated in line between the master and slave cylinders. Then i could just have a braided clutch line made up that runs from the master cylinder directly to the slave cylinder. Surely this would be better for pedal feel and be easier to bleed.
Also, i wouldnt mind knowing what its for before i remove it altogether. See the pic below; its the funny black box that has a bleed nipple on it and lines running into and out of it.
Also, does anyone know of people who would make a braided line that runs from the master cylinder to the slave cylinder?
Thanks,
Shaun
yeah you can do exactly that, and it does make bleeding much easier. UAS sell a straight braided replacement for a good price, we just put one in the car today.
here's a pic of it from another thread
Isn't that block part of the clutch fluid cooler. Wouldn't removal of that block leads to overheating/boiling of the fluid?
Mine was removed when I purchased the car. I've been thinking of getting one to try and see if there is any benefit.
Shaun, don't bin that unit and make a donation by sending that unit to me :D?
nar it wont cool anything, there isnt really a flow in the clutch system, if you want to blled the clutch well with the block, i found to bleed the clutch through the slave, and then go to the block bleed it from the block, and then back to the slave,
but
i would much rather 1 line haha, but i cant because my lines are rounding the bolts trying to get them off so im just leaving it.
if you really want one I am pulling another one off next weekend. but unless you want to pick it up in syndey postage would be a killer
Shaun....MAKE A DONATION (I really want it on a faster server right now :D )
Thanks for the reminder Duncan! +1 for faster server too.
UAS sell them for $120 which isnt too bad.
Now for another question. Is it a worthwhile upgrade to get the Nismo larger slave cylinder rather than a stock replacement one? I think the Nismo ones are about $80 or $90 extra.
Thanks again,
Shaun.
  • 5 weeks later...
Thanks again,
Shaun.
i got the UAS one and all i can say it AWESOME. bleeding the clutch 5 minutes (max) i did matster, slave and cable and im never looking back. the clutch feels great and alot heavyer
I got a braided line made up from a brake and clutch place; they said it would be $60 but they forgot to charge me for it!
I've got a braided line that I've been meaning to fit but haven't yet. Was going to do it while my suspension is out being rebuilt in the next few weeks but does it really make the clutch a lot heavier? I was also looking into the Nismo slave to make it lighter as that's all it does that different to stock. Then I thought, I bet we can find a local slave the right size that will do the job. Any ideas? Gotta find the internal diameter of the stock and Nismo ones again. I had the measurements but I lost them.
Shaun, don't bin that unit and make a donation by sending that unit to me :mellow:?
Yup, it's the cooler.
Bypassed mine, and two other Skylines with no adverse affect.
Bin it bro!
well im about to bin mine, tried every bloody adjustment and 3 bottles of clutch fluid later i still cant dis-engage so i cant even get the car into gear,
apparently when you get a heavy pressure plate etc.... theres a point where you rubber hose to the slave will just exspand instead of pushing the slave out because of the pressure which is needed,
so my APP 1 piece braided line arrived today, will put it in tomorrow and i hope my clutch works, otherwise i will be cut,
(that box thing was the dumbest design ever)
Don't forget to bleed the master first, then the slave. Otherwise you'll be bashing your teddy man. I learned the hard way......
Pretty sure its not a cooler, it wouldnt work, and the clutch fluid has no reason to get hot
Yeah man it is a cooler. The workshop manual even states it.
The reason the fluid gets hot is because of compression. If you pump the pedal enough it will heat the line.
They're not use on brake lines because they run the length of the vehicle and the underbody draught cools the lines.
Anything under compression develops heat - A case in point: Turbos.
  • 4 weeks later...
How did you go with this?
I am in the same boat, except ive lost my slave cylinder in moving sheds. So I can't even take my old one is for a sample.
Apparently the difference between Std and nismo is 19.05mm vs 20.54mm, with the current exchange rate its pricing them upwards of $200. And im sure a PBR or Powermax wouldn't be more than $60.
Infact I reckon a Patrol one would do the job.
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
