Hi,
I just bled my clutch because im having disengagement problems, and was wondering if i can remove this distribution (?) block that is situated in line between the master and slave cylinders. Then i could just have a braided clutch line made up that runs from the master cylinder directly to the slave cylinder. Surely this would be better for pedal feel and be easier to bleed.
Also, i wouldnt mind knowing what its for before i remove it altogether. See the pic below; its the funny black box that has a bleed nipple on it and lines running into and out of it.
Also, does anyone know of people who would make a braided line that runs from the master cylinder to the slave cylinder?
Thanks,
Shaun
yeah you can do exactly that, and it does make bleeding much easier. UAS sell a straight braided replacement for a good price, we just put one in the car today.
here's a pic of it from another thread
Isn't that block part of the clutch fluid cooler. Wouldn't removal of that block leads to overheating/boiling of the fluid?
Mine was removed when I purchased the car. I've been thinking of getting one to try and see if there is any benefit.
Shaun, don't bin that unit and make a donation by sending that unit to me :D?
nar it wont cool anything, there isnt really a flow in the clutch system, if you want to blled the clutch well with the block, i found to bleed the clutch through the slave, and then go to the block bleed it from the block, and then back to the slave,
but
i would much rather 1 line haha, but i cant because my lines are rounding the bolts trying to get them off so im just leaving it.
if you really want one I am pulling another one off next weekend. but unless you want to pick it up in syndey postage would be a killer
Shaun....MAKE A DONATION (I really want it on a faster server right now :D )
Thanks for the reminder Duncan! +1 for faster server too.
UAS sell them for $120 which isnt too bad.
Now for another question. Is it a worthwhile upgrade to get the Nismo larger slave cylinder rather than a stock replacement one? I think the Nismo ones are about $80 or $90 extra.
Thanks again,
Shaun.
  • 5 weeks later...
Thanks again,
Shaun.
i got the UAS one and all i can say it AWESOME. bleeding the clutch 5 minutes (max) i did matster, slave and cable and im never looking back. the clutch feels great and alot heavyer
I got a braided line made up from a brake and clutch place; they said it would be $60 but they forgot to charge me for it!
I've got a braided line that I've been meaning to fit but haven't yet. Was going to do it while my suspension is out being rebuilt in the next few weeks but does it really make the clutch a lot heavier? I was also looking into the Nismo slave to make it lighter as that's all it does that different to stock. Then I thought, I bet we can find a local slave the right size that will do the job. Any ideas? Gotta find the internal diameter of the stock and Nismo ones again. I had the measurements but I lost them.
Shaun, don't bin that unit and make a donation by sending that unit to me :mellow:?
Yup, it's the cooler.
Bypassed mine, and two other Skylines with no adverse affect.
Bin it bro!
well im about to bin mine, tried every bloody adjustment and 3 bottles of clutch fluid later i still cant dis-engage so i cant even get the car into gear,
apparently when you get a heavy pressure plate etc.... theres a point where you rubber hose to the slave will just exspand instead of pushing the slave out because of the pressure which is needed,
so my APP 1 piece braided line arrived today, will put it in tomorrow and i hope my clutch works, otherwise i will be cut,
(that box thing was the dumbest design ever)
Don't forget to bleed the master first, then the slave. Otherwise you'll be bashing your teddy man. I learned the hard way......
Pretty sure its not a cooler, it wouldnt work, and the clutch fluid has no reason to get hot
Yeah man it is a cooler. The workshop manual even states it.
The reason the fluid gets hot is because of compression. If you pump the pedal enough it will heat the line.
They're not use on brake lines because they run the length of the vehicle and the underbody draught cools the lines.
Anything under compression develops heat - A case in point: Turbos.
  • 4 weeks later...
How did you go with this?
I am in the same boat, except ive lost my slave cylinder in moving sheds. So I can't even take my old one is for a sample.
Apparently the difference between Std and nismo is 19.05mm vs 20.54mm, with the current exchange rate its pricing them upwards of $200. And im sure a PBR or Powermax wouldn't be more than $60.
Infact I reckon a Patrol one would do the job.
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
