bubba Posted November 6, 2008 Share Posted November 6, 2008 I whacked a braided line in on the weekend (old rubber hose was weeping where it went into the slave cylinder), binned the distribution block and the cooler pipe. Clutch feels a LOT nicer now, not heavier or lighter but feels somewhat more "direct" if that makes sense Link to comment https://www.sau.com.au/forums/topic/233206-can-i-remove-this-distribution-block-between-the-master-cylinder-and-slave-cylinder-r32-gtst/page/2/#findComment-4244798 Share on other sites More sharing options...
ellie Posted November 6, 2008 Share Posted November 6, 2008 Can't help but wonder why the factory saw fit to have it there in the first place. I think there is sound logic to upgrading things but the engineers that designed such a fantastic car with great longevity are no idiots. Has anyone actually pulled the cooler distribution box apart before? The pipe which the factory use is relatively easy to work also, so, maybe the block can be taken out and replaced with a short finned section like on the P/S cooler on GTRs? Obviously replacing the short rubber hose with braided. Just food for thought anyways. . . . Link to comment https://www.sau.com.au/forums/topic/233206-can-i-remove-this-distribution-block-between-the-master-cylinder-and-slave-cylinder-r32-gtst/page/2/#findComment-4245557 Share on other sites More sharing options...
Abo Bob Posted November 6, 2008 Share Posted November 6, 2008 They do it to make the car smoother which has the effect of reducing the feel. We don't mind the harshness cos we want the raw feel. Same reason they put soft suspension and sound deadening in there. They take the NVH out and we spend years putting it back in! Link to comment https://www.sau.com.au/forums/topic/233206-can-i-remove-this-distribution-block-between-the-master-cylinder-and-slave-cylinder-r32-gtst/page/2/#findComment-4246151 Share on other sites More sharing options...
ellie Posted November 7, 2008 Share Posted November 7, 2008 That is a valid point you make! They would make the system with Tom,Dick and Harry in mind. And I am actually about to replace mine mainly because of the whole new world that braided brake lines opened up to me. It was a major improvement and I can only imagine the clutch should have similar improvement with engaugement feedback. Link to comment https://www.sau.com.au/forums/topic/233206-can-i-remove-this-distribution-block-between-the-master-cylinder-and-slave-cylinder-r32-gtst/page/2/#findComment-4247472 Share on other sites More sharing options...
jjcb Posted September 11, 2017 Share Posted September 11, 2017 Hey everyone, Sorry to dig up an old tread but I'm in the process of changing my clutch line (R32 gtr). From the master direct to the slave. Just want to know what happens to the connection to that distribution box? (Where it originally went from master to the distribution box). Do you just leave it or put a bolt in there? Thanks in advance! Link to comment https://www.sau.com.au/forums/topic/233206-can-i-remove-this-distribution-block-between-the-master-cylinder-and-slave-cylinder-r32-gtst/page/2/#findComment-7849264 Share on other sites More sharing options...
KiwiRS4T Posted September 11, 2017 Share Posted September 11, 2017 What connection? Just run the line from M/C to slave cylinder. Link to comment https://www.sau.com.au/forums/topic/233206-can-i-remove-this-distribution-block-between-the-master-cylinder-and-slave-cylinder-r32-gtst/page/2/#findComment-7849297 Share on other sites More sharing options...
niZmO_Man Posted September 12, 2017 Share Posted September 12, 2017 I threw mine in the (metal recyclers) bin. Link to comment https://www.sau.com.au/forums/topic/233206-can-i-remove-this-distribution-block-between-the-master-cylinder-and-slave-cylinder-r32-gtst/page/2/#findComment-7849309 Share on other sites More sharing options...
jjcb Posted September 12, 2017 Share Posted September 12, 2017 Ok cool, thanks for the help! Link to comment https://www.sau.com.au/forums/topic/233206-can-i-remove-this-distribution-block-between-the-master-cylinder-and-slave-cylinder-r32-gtst/page/2/#findComment-7849359 Share on other sites More sharing options...
