I am trying to find the plug/connectors for the reverse lights. This is the other socket(s) that I have in mind.
Anyone tell me which two pins are for the reverse lights?
This socket is front left next to the radiator. I will post aother pic of its position.
Thats the neutral switch you can see bridged - my guess is the reverse lights are somewhere in these sockets.
That first picture of the plug with the yellow circle around it is an ABS sensor plug.(100% sure)
I'am pritty sure its the Grey 8 pin plug that has a pin missing the one just below your bridged neutral plug that contains the reverse lights.
From memory mine went:
Pin location on grey 8 pin plug:
......1......................2......................3......................4
.........................................................................(Power)
......5......................6......................7......................8
(missing).............(nuetral)............(Reverse).................
On the Gearbox the reverse switch will be the one closest to the bell housing, the neutral switch is closest to the selector. I had to run some wires from the reverse switch on the gearbox to this grey plug.
Hope this helps!
MEGA
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
