FWIW Fenix are made in NZ, not China. I've used them before with no issues too.
Correct I only know how inflict pain on myself. -
So you can then buy a more expensive, less reliable, more boring and slower replacement that's harder to work on and you have no knowledge of?
Will take much better photos when the time comes, I still want to do a sub 1m50s on street tyres at SMSP (just because). Then will slap on proper tyres and see if the car can get down to 1m40~45s range. If it goes sun 1m40s without aero, then wow.. but I don't expect the shit box to go that fast. -
I have the OS Giken R3C with the GM 26 spline input shaft in my 32(Rb32 with only around 750hp atw) and its a pig to drive. Its actually very forgiving when its cold when when its warmed up, it chirps the tires even when trying to take off slowly. Mind you though, part of this has to do with my clutch master(Non-OEM) so the travel on the rod is shorter. How did you get 1130hp at 85% @e50?! Are you running a stroker? If so, I would recommend the R3C purely because it handles the abuse.
