I had a quick look around the forum and I could not see any threads directly related to V Series pictures (nothing in the Gallery Section either). I thought it would be interesting to see what fine examples we have on show?
EDIT by Nismo
Seeing as there was a lot of chat in the other pic threads, I'll sticky this one and make it NO CHAT, PICS ONLY.
All non pic posts will be deleted. PM me if anyone has any concerns.
Cheers
Bobby
https://www.sau.com.au/forums/topic/233300-v-series-gallery/
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
Ah finally, I have been waiting for this car to appear on the forums. I have seen this cruising around and know the seller. Its the only Lakeshore Blue sedan I have seen in QLD apart from mine.
Looks almost identical to mine except for the wheels, wing and grill. As far as I'm aware, the only thing aftermarket is the grill, wheels, and stereo. You've also got factory front cameras and also the OEM lip which are rare options.
I suggest you lower it quick smart :P Welcome to the forums!
Here's mine, don't forget to wave if you see me..
  • Like 1
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
