^^ haha slightly reminiscent of these old pics of my R34 (before I sold it) and my V35 (when it was stock) :D
Hahaha yeah, it's hard to believe how they went from the R to V series isn't it, such different cars in so many ways. So why did you sell the 34?
BTW nice photos Sheldon, love those wheels.
The 34 had done 160,000km and was getting very long in the tooth. Power steering hose failed (cost $500 to fix with a custom braided item), radiator let go, various heater hoses were leaking/failing every other week .... plus I had been running 230rwkw for 50,000km and I had a feeling the motor was not going to last a vast amount longer. Plus it was my work car, so reliability was the big issue.
On the upside the V35 is flawless, runs 175rwkw and is a perfect daily work car with full on luxury. Love it to death. I wanted a V36, but 2 years ago when I bought the V35, V36s were $55k in black .... way too much. More affordable now, but now I have modded/set up the V35 to such a level that I couldn't bear to lose heaps of $$$ on it and start again.
On the upside the V35 is flawless, runs 175rwkw and is a perfect daily work car with full on luxury. Love it to death. I wanted a V36, but 2 years ago when I bought the V35, V36s were $55k in black .... way too much. More affordable now, but now I have modded/set up the V35 to such a level that I couldn't bear to lose heaps of $ on it and start again.
Fair enough. Kind of at the same crossroad myself now, so was interesting to hear your story. Strangely it's so similar to mine, only difference is I went down the massive engine rebuild path, just now though the alternator died, fuel gauge is randomly not working and other small, random stuff going wrong. Kind of getting expensive now just to maintain (especially since I have 3 cars now!) so rego, insurance and maintenance on all cars is on my mind. The 34 runs perfect mechanically, just wondering if I've outgrown it though.
I suppose the only problem I have is that the 36 kind of does everything the 34 does, but better. Except for the turbo, wish the 36 had that :) Then there's the cops, every Falcodore wanting to drag at every set of lights, the never-ending mods and maintenance costs... is it worth it?
Sorry for rambling guys, been thinking about it for the past few weeks and wanted to vent to other car nuts who would understand lol :)
No you are not rambling Steve .... it the exact thought process I went through .... in the last 3 months I owned the R34 I put on stainless braided brake lines, new silicone heater hoses, gold passivated slotted rotors and all sorts of little items, but the fact is things were going to keep going wrong and how much should you pour into an old car?
My thoughts for you are easy - sell the R34 and use the funds supercharge the V36. Saves 1 extra lot of rego/insurance, plus once you have spent the $10 on the supercharger and accessories you will have 300rwkw in a very comfortable luxury cruiser that doesn't attract police attention :thumbsup:
Thanks for the advice Andrew, pretty sure I will get rid of the R34 next year anyway - have already thought about turbo/super-charging the V36, after all the headaches I've been through with the R34 though, kind of want to shy away from modifying again. Been doing it for too many years, to start doing it again would probably drive me mad. :)
Kind of why the V36 is stock standard, wanted to keep it like that. Actually knocked back buying a modified V36 when I bought mine last year (had HKS Adjustable Coilovers, Project Mu brakes/rotors, 5Zigen exhaust), just didn't want the hassles with getting defected or anything. Decisions, decisions...
Posted these in the Vic 'post your ride' thread earlier today, thought I'd put it here. A couple pics of my R34 and V36 - figured it was a nice day for it. :)
Steve did you paint the front grill black? If so did you use the plastidip stuff they are all using in the states or is that permanent paint.
cheers
oz
cheers
oz
I just got it sprayed (free) at my mate's panel beating shop when my car was reversed into earlier this year; not sure about the paint but it's a gloss black finish on it. Just ended up buying some chrome strips later that I cut to size to finish off the top and bottom to give it that midnight grille look. It's not perfect up close but it's pretty good, looks heaps better with the chrome on though.
It does look good. First thing I picked up on when looking at the pics
Edited by scarf
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
